20 Most Recent Coleman Cable Power Inverter PMP1200 Questions & Answers
What does it invert?Higher voltage to lower or what?Either way,with 1200 watts being inverted,it is not a good idea to charge a battery with that kind of power.Batteries need to be charged low and slow.We are talking milliamps for hours.Fast charging a battery results in a very good chance of explosion,which is never good.Acid from the battery will go everywhere.
Coleman Cable... | Answered on Aug 04, 2010
it is possible the alternator's power is higher than that of the inverter ,that is overload
Coleman Cable... | Answered on Feb 25, 2010
please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Coleman Cable... | Answered on Nov 17, 2009
first, red gets placed on positive, then black on negative
Coleman Cable... | Answered on Oct 31, 2009
An incandescent lamp that is cold takes approximately 10 times the running current initially. The inverter MAY not be able to start the 500 watt lamp if its protection circuits sense the very low starting resistance of the lamp.
Test the inverter on some other device first.
Coleman Cable... | Answered on Jul 26, 2009
There are some fuses at the output. plus the protection on the AC panel. Start at the Inverter output and check fuses and power there, then work your way out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Coleman Cable... | Answered on Jul 03, 2009
I have an older pmp1200 and NO, you don't have to take the back off. Those spade fuses are for an empty RV power buse position where you will connect the inverter to fuse the DC side. The PMP 1200 has pertection circuts inside for overload, but if a short on DC input were to occure it would not pertect your buse (and of course the battery) from causing a posible fire situation. Since the DC cable size needed for the maximum curent draw on this unit is so large (4 gage), I would recomend a direct battery conection fused via a fuse holder that can handele the max current (10 amps). Check with your local battery stores for such items. Warning: don't use fusing over this 10 amp rating because if the unit happens to short, it could start the battery to over heat and cause a fire or battery explosion.
Coleman Cable... | Answered on Jun 03, 2009
no such product
Electronics -... | Answered 2 days ago
Please use laptop having serial port if not available then purchase a new original usb to serial of famous brand like Siemens, Lenze, MITSUBISHI, local brands may not works.
Electronics -... | Answered on Nov 25, 2020
There is not and those are not easy to get. China sites like alliexpress has them if you want to chance it.
Electronics -... | Answered on Nov 14, 2020
There are several ways to do this and several complications that may arise. That said, here is a brief outline of one method:
1. Locate the music folder on your PC.
2. Insert your flash drive into the USB port (allowing time for it to install or access drivers).
3. Click on Start, select My Computer. Locate your flash drive (most likely list as Removable Disk or the brand name of the flash drive). Double click on that icon.
4. Right click the folder or music files you found in step 1. Select "Send to" and choose "Removable Disk." The transfer process may take several minutes depending upon the number of files you are transferring. After the transfer is complete, click on the USB flash drive icon on the Windows task bar and select Stop or Eject. The PC will advise you when it is safe to remove the flash drive.
Here is a link to other ways to put music on a Flash Drive:
https://www.wikihow.com/Put-Music-on-a-Flash-Drive
https://www.youtube.com/watch?v=EQ4HSnlJiao
Electronics -... | Answered on Aug 03, 2020
  1. Remove the memory card from your camera.
  2. Insert the memory card into your laptop's PC card slot. ...
  3. Locate the destination folder where you want to store your pictures, in your laptop. ...
  4. Open the destination folder of your choice [source: Dummies.com]. ...
  5. Select Import pictures to my computer from the choices offered.
Electronics -... | Answered on Jun 17, 2020
Coleman Cable Power Inverter PMP1200 Logo
17 questions posted
Top Coleman Cable Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Coleman Cable Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Cable Electronics - Others
Most Popular Question
attach inverter custom battery cables
  • Electronics - Others
