20 Most Recent American Standard 1340M.105.002 Polished Chrome Pillar Tap Metering Faucet Questions & Answers
Hot water tap continues to leak after
Hi check the valve seating some thing cold be stuck on it or change the valve body
2/10/2010 5:28:41 PM • American... • Answered on Feb 10, 2010
Just installed a kitchen faucet and now it leaks when on at the b
sounds like you may have clogged the little screens at end of spout try unscrewing and see what happens if not you may be suffering from the returned part open box syndrome
5/11/2009 3:19:39 PM • American... • Answered on May 11, 2009
5answers
Clogged sinks and toilets
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
4/6/2022 3:13:10 PM • American... • Answered on Apr 06, 2022
2answers
I had an American Standard 4005 Fairbury faucet installed 9 days ago and now the hot water doesn't work. does anyone know what is happening?
The faucet may have been installed incorrectly (even backwards).
4/9/2021 5:42:00 AM • American... • Answered on Apr 09, 2021
How to install an American Standard goose neck 2 handled kitchen faucet, is there a step by step instructions with diagram?
American Standard has the Installation Guide for some of their kitchen faucets on each product's page. A list of some of their two-handle kitchen faucets is available here: https://www.americanstandard-us.com/kitchens/kitchen-faucets?No.%20of%20Handles=Two&page=1&plimit=21 . Home Depot has the Installation Guide for the Heritage wall-mount faucet with Goose Neck spout on the product page: https://www.homedepot.com/p/American-Standard-Heritage-2-Handle-Wall-Mount-Kitchen-Faucet-in-Polished-Chrome-with-Gooseneck-Spout-7293-252-002/100080273 . The current link to the guide is https://images.homedepot-static.com/catalog/pdfimages/de/deca2fce-73fc-47a2-acb5-efc7232dac17.pdf . These are standard plumbing installation guides. They condense most of the steps of the hardware install into one diagram/step of the guide. I hope this helps. If you need further assistance, please add more information on the style of your faucet. (Is it a wall-mounted faucet or a sink-mounted faucet?) Cindy Wells
8/6/2020 11:41:23 PM • American... • Answered on Aug 06, 2020
How do I remove the handle on an american standard Jasmine amarilis single handle kitchen faucet
https://www.youtube.com/watch?v=wA7aLHZ84D4
3/26/2020 4:42:18 PM • American... • Answered on Mar 26, 2020
How to remove and replace pull down hose and head in an american standard kitchen faucet?
Download the BILT app and search for your faucet model. The icon is turquoise with a white nut ( as in nut and bolt).
It will show you step by step nearly everything under the sun. Hope that helps a bit.
11/9/2019 2:46:40 AM • American... • Answered on Nov 09, 2019
Speed connect drain will not go down completely
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
12/10/2018 11:24:22 PM • American... • Answered on Dec 10, 2018
American Standard Edgewater Single handle pull out faucet. Hot water pressure trickles.
mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
9/27/2018 1:53:22 AM • American... • Answered on Sep 27, 2018
American standard 2k-2h still leaks after replaceing sem and nut
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
4/13/2018 10:58:01 PM • American... • Answered on Apr 13, 2018
How do i remove bathroom sink drain plug?
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
1/12/2018 10:02:19 PM • American... • Answered on Jan 12, 2018
I need a daigram of
I would google it . Or look on u tube
1/12/2018 2:52:14 AM • American... • Answered on Jan 12, 2018
How to replace the trap for kitchen sink..there is
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
9/13/2017 12:13:07 AM • American... • Answered on Sep 13, 2017
How to fix leaky American Standard single faucet kitchen sink
The A-S single lever kitch faucet is terrible. If it is the one I think it is, then it has three screws that mount the cartridge down into the faucet body.If these are not torqued perfectly evenly, the faucet leaks. I suggest getting a Moen to replace it.
5/20/2017 3:21:33 AM • American... • Answered on May 20, 2017
I just replaced cartridge for American standard with danco part #188260 and it still drips.can you help me?
As this is the A-S ceramic cartridge that installs with three screws, then I suggest you either buy the original part, or just get a new faucet. The three screw type is notoriously difficult to seal properly because of the design. If you do replace it, I recommend Moen single handle. It's basic cartridge has a lifetime warranty against dripping, and is super simple to change out. Good luck!
4/16/2017 5:28:12 PM • American... • Answered on Apr 16, 2017
Odor coming from water in my home.
I have had this for no reason it smelt as you say The only thing is you may have disturbed the pipes Odd I know drives you mad , As you say a softener would do the trick . or maybe if your on a well , A well flush but they cost .
3/21/2017 9:59:21 PM • American... • Answered on Mar 21, 2017
The gooseneck on an American Standard 4005caf has too much play in it. How do I fix it?
common porblem looks like a long thread at its base .. might be able to tighten up the slack 26353970-blybzp5fcnz11ohm3j2nqlqo-2-0.gif American Standard 4005SSF Fairbury Kitchen Faucet Parts
11/13/2016 9:22:24 PM • American... • Answered on Nov 13, 2016
How to rethread a gooseneck faucet?
go to a tool and bolt retailer and get the correct thread tap the cost to do the job will be larger that a new tap
9/9/2016 11:32:09 PM • American... • Answered on Sep 09, 2016
American Standard 1340M.105.002 Polished Chrome Pillar Tap Metering Faucet Logo
2 questions posted
Top American Standard Plumbing Experts
john h
Marvin
Marvin
Paul Carew
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Plumbing
Most Popular Question
hot water tap continues leak after
  • Plumbing
