20 Most Recent Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Questions & Answers
know your key pad number?when changed?does it have a battery?
Kwikset 907 ... | Answered on May 02, 2016
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Kwikset 907 ... | Answered on Mar 12, 2016
You should take the cover off and make sure the wires are properly connected. I had the same problem and that is what was causing it.
Kwikset 907 ... | Answered on Dec 02, 2013
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Kwikset 907 ... | Answered on Jul 07, 2013
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Kwikset 907 ... | Answered on Dec 29, 2012
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Kwikset 907 ... | Answered on Jul 11, 2012
Why is my Powerbolt beeping?
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Good luck--and please provide feedback if this helps!
Kwikset 907 ... | Answered on Nov 10, 2011
Installation instructions:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
You will also find contact information for further assistance from Kwikset.
Kwikset 907 ... | Answered on Nov 09, 2011
This link:
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Installation instructions for the Kwikset 907 link:
This is the link to Weiser Customer Support Page, where you will find the appropriate number for your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Kwikset 907 ... | Answered on Nov 08, 2011
I would recommend verifying that the batteries are new and installed correctly. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Here is the link to the installation instructions:
I think that you may have the door jumper set in the wrong position for the way your door opens (door handing; see page 6 of the instructions).
Kwikset 907 ... | Answered on Nov 06, 2011
Kwikset 907  907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Logo
75 questions posted
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Kwikset Locks & Locksmithing
Most Popular Question
kwikset electronic deadbolt
  • Locks & Locksmithing
