20 Most Recent
Deadbolt Zurich Digital Keyless Remote Control Lock Brass-WITH REMOTE Questions & Answers
J'ai changer les bateries de
Le code maitre est "0123". Poussez que, puis "S". Entrez un nouveau code. Il doit commencer par "0". Saisissez le nouveau code, appuyez sur "On".
I have a touchpad Zurich
I have been searched unsuccessfully for "Zurich deadbolt keyless remote" in order to help you. However, if the picture shown in your request is accurate for your lock, I have found some information which may be useful to you!
The brand that I found is Lockstate, which looks like the lockset pictured. Go to this webpage (copy & paste into your browser search window):
http://www.lockstate.com/manuals-and-downloads.html?start=10
Go to the bottom of that page, to "LOCK LS-DBS" and click on Download. This will download a PDF file of the installation and programming instructions.
If you cannot open and view the download, you will need to download and install Adobe Reader. You can get it here:
http://get.adobe.com/reader/
If this is not the correct information for your lock, please re-submit the problem and I'll try again. Any further model info, etc., will be helpful.
Good luck--and please provide feedback if this helps!
I lost my xt-33 I bought a newone and dont know
http://www.audioreaction.com/Manuals/RS725LCD%20Operation%20Manual.pdfA note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:http://get.adobe.com/reader/Good luck!
I have a Rona keyless lock with two fob remotes
I've located a number that you can call for RONA customer service:
1-866-283-2239
8 a.m. to 8 p.m. (Eastern Time)
Monday to Friday
I believe this is the link to RONA where you find your lock featured for sale:
http://www.rona.ca/shop/~deadbolt-digital-deadbolt-rona-collection-253947_locksmithing-accessories_rona-product-line_shop
Unfortunately, there is no downloadable instruction manual to download, ETC., so call the number and begin the process--I hope you get an answer without too much telephone runaround!
Good luck!--and please give feedback if this helps you toward a solution.
Technical
The lock's fingerprint recognition technology has a failure rate of 1 in 1 million - far lower than an old fashion 5 lever mortice lock. You'd have to be flippin' unlucky for an unathuorised access. However, you should be advised that early devices have been discovered to be vulnerable to quite simple methods of deception, such as fake fingerprints cast in gels. But who do you know that will take your fingers and deep them in a gel? That's a lot of work for someone who just wants to get into your house. He'll be better off if he'll go to you neighbor's house.
Resetting Master pin on rona Electronic Deadbolt lock
GoogleRona Electronic Deadbolt Lock Instructions:Default Master Code:123Resetting Master PIN:Remove batteries and put them back. You will hear a long beep and a short beep.Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.Adding a PIN:Key in master PIN and press UNLOCK buttonPress and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.Release 0 button and you are in the Add PIN modeWithin 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.make model resetting lock
https://www.google.com/search?q=resetting+Master+pin+on+rona+Electronic+Deadbolt+lock..
I had to replace my batteries in my electronic deadbolt and now it won't let me reset the code and I've followed the directions and not working
You didn't say what brand or model, so here's a generic answer:
Find the instructions to reset it to factory codes. Sometimes this is as easy as removing the battery and waiting an hour (or a day) and other times you have to enter special codes, or disconnect a jumper, or connect 2 points with a wire to erase the codes. Once you have the lock reset, put brand new batteries in and follow the instructions for programming a brand new lock.
If you don't have the instructions, you can often find them online by entering the brand and model # into the search box of Google or YouTube along with a word or phrase like "instructions" or "manual" or "getting started."
