20 Most Recent Kohler Model 7202: Drain For Purist® Baths - Polished Chrome Questions & Answers
Water is leaking from bath tub drain
the most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
11/14/2013 6:25:44 PM • Kohler Model... • Answered on Nov 14, 2013
2answers
The tub has not had any problems draining. Drained
HI buy some draino put it down the drain remove the water first , then add draino should work then
9/19/2011 9:58:52 PM • Kohler Model... • Answered on Sep 19, 2011
Water pours out of faucet
The divertor is bad inside the faucet spout. Solution is to replace entire spout.
9/16/2010 3:08:00 AM • Kohler Model... • Answered on Sep 16, 2010
Tub drain will not stay in up position
Hi it may well do clogged up in drain hole or it may have come loose inside try tighenting up
2/10/2010 5:45:21 PM • Kohler Model... • Answered on Feb 10, 2010
When i turn the cold water faucet off water still
I dont know the modle fauset you have ,but it sounds like your cartridge has turned in the valve body. It should lock into place in the valve body with a tang in the cartridge and a slot or groove in the fauset body. If the whole cartridge assembly turns in the fauset it will couse this problem.
12/28/2009 8:58:11 AM • Kohler Model... • Answered on Dec 28, 2009
K-1357 kohler whirlpool tub
You say that it doesn't leak during showers. The next step is to plug the drain 100% so no water will drain thru the drain assembly. Fill the unit up to just below the overflow drain and leave overnight to see if it could be leaking from the outside of the drain plug assembly or leaking from the jets/drain from the whirlpool feature. If was just recently installed was it professionally installed. Should be covered by warranty.Try this then if its not determined what the cause we will go to the next level of investigating what it could be.in it peak all around to see where the water is comming from. Use a flashlite so your not kneeling in mosture with a electrical light in your hand!!! Good Luck!
7/8/2009 1:42:42 AM • Kohler Model... • Answered on Jul 08, 2009
Kolher archer shower and tub faucet unit
you may have a defective shower stem, need to go back to store to have it replaced.
6/24/2009 2:55:12 PM • Kohler Model... • Answered on Jun 24, 2009
2answers
Bathtub Will Suddenly Not Drain
tyr and use a plunger
it probaly has a lot of hair in it.
I do mine every couple month
5/14/2009 3:48:31 PM • Kohler Model... • Answered on May 14, 2009
My bathtub will suddenly not drain
you need to use a hand snake you have to push the debris past the s trap
5/3/2009 6:54:57 PM • Kohler Model... • Answered on May 03, 2009
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
3/10/2009 2:10:40 PM • Kohler Model... • Answered on Mar 10, 2009
Urinal won't flush
hi not being american it sounds as though its a solenoid problem, although the water supply is ok & the batteries are fine, if the solenoid is at fault then no water willpass, or possibly if there is a strainer in the water supply it may be blocked & needs cleaning out?
Hope this helps
Richie from the UK
12/15/2008 6:50:23 PM • Kohler Model... • Answered on Dec 15, 2008
Blockage Maintenance
# Regularly remove any hairs that get trapped in the waste plug hole. # Keep small objects such as combs, medicine bottles and toilet rolls away from places where they could accidentally fall into the toilet. # Regularly flush the wash basin and bath or shower pipe work with hot water and a disinfectant to clear soap residue and prevent build up over time. # Don’t flush away large and disposable items such as sanitary towels, nappies or product wrapping as they can become caught in the drainage pipe. # Do not dispose of waste food scraps and cuttings down the kitchen sink. These are much better composted. If any items do fall into the sink pull the vegetable material out of the plug hole, do not try to poke through as you could impact the blockage making it harder to remove. # Never dispose of cooking fats down the drain system. As they hit cold water they will solidify. If there is absolutely no alternative you should dilute and emulsify the fats by mixing them with hot water and of detergent. Keep the water running for a minute after you have done this to keep a clear water flow. # For complete peace of mind, particularly if you are running a business you can request a regular drain surveys and get your drainage system checked regularly by a CCTV drain inspection service. This will give early warning of any potential blockages and also enables you to keep an eye on the structural condition of the drainage pipe work.
8/27/2008 12:30:17 PM • Kohler Model... • Answered on Aug 27, 2008
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps: First, turn off the water supply to the faucet. Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key. Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off. Once the plastic insert is removed, you should be able to access the cartridge. If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
1/14/2024 12:29:26 PM • Kohler Plumbing • Answered on Jan 14, 2024
Manual and guide to replacing parts in Kohler Model 10430
Parts diagrams. Instruction for changing are normally on the Kohler website. Or Google make model replace (the part). https://www.google.com/search?q=kohler+model+10430+replacement+parts ..
12/4/2022 12:47:33 AM • Kohler Plumbing • Answered on Dec 04, 2022
2answers
Have Taboret K 8201-4 bathroom faucet with T handles.
Question edited to fix the typos. Always worrying when they discontinue lines, and it makes you wonder why? https://www.us.kohler.com/us/taboret-centerset-bathroom-sink-faucet-with-lever-handles/productDetail/product:420060/420060.htm I normally find that they use steel screws and they stick. Make some sort of a dam around the screw with stout polythene like Ziploc bag and electrical tape to seal the base. Then squirt penetrating oil or WD40 in there to cover the screw head. Top it up a couple of times a day and do that for two days. That should loosen it up and get the oil down the threads. Often it is just easier to buy a new set.
9/23/2022 12:45:42 PM • Kohler Plumbing • Answered on Sep 23, 2022
Tines stripped on recessed aerator how to remove
call kohler
12/13/2021 11:09:03 PM • Kohler Plumbing • Answered on Dec 13, 2021
Is there a video of replacing o ring on a 77809/AA kohler leaking under handleplease
you tube is the video website
5/28/2021 5:05:40 PM • Kohler Plumbing • Answered on May 28, 2021
Kohler one handle shower faucet fixture will not turn off
Look up the Kohler 800 number. Their parts have a lifetime warranty and they will gladly send a replacement part.
11/6/2019 10:53:41 PM • Kohler Plumbing • Answered on Nov 06, 2019
Kohler Model 7202: Drain For Purist® Baths - Polished Chrome Logo
19 questions posted
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Kohler Plumbing
  • Kohler Plumbing
Most Popular Question
water leaking from bath tub drain
  • Plumbing
