20 Most Recent V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Questions & Answers
The voltage regulator may be bad, will need to unplug magneto and use multi meter and test magneto for voltage output on milliamp scale with the engine cranking, If voltage is present when cranking then the voltage regulator is bad , if no voltage then the pick-up coil and stator will need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/darryl_24e8d8d43e609e3c
V-Twin... | Answered on Aug 26, 2019
Hi, if it's a newer style bike, it could be like a newer car. Not possible to change the timing.
V-Twin... | Answered on Feb 10, 2017
I have the same problem...did you find a solution? If so please email me at [email protected].
THANKS!!!!!
V-Twin... | Answered on Jan 17, 2017
Check the flywheel keyway, they will shear and cause the problem you are encountering.
V-Twin... | Answered on Oct 06, 2015
Pull the spark plugs out and check their color - as this will tell you if the engine is flooding out or you have an ignition system failure. If they are black check to make sure the choke is opening up and staying open. If the ceramic is light and not brown then the ignition system is failing.
Carb. problem. rebuild or buy a new one
V-Twin... | Answered on Aug 12, 2015
What ussually causes white smoke to come out the exhaust is oil being sucked up in carb. Typical causes are too much oil in crank case or PVC valve. Or really bad piston rings
V-Twin... | Answered on Apr 12, 2015
How many miles are on it?
It could be worn out rings, valve guides and seals, cylinder could be worn out of specs, etc.. Either way, too much oil is entering the combustion chamber.
V-Twin... | Answered on Feb 24, 2015
rebuild or replace the carb- it isn't working properly. You may just need to clean it good as there may be a partial blockage.
V-Twin... | Answered on Jan 03, 2015
It goes to the motor and grounds the ignition that gives it power. looks like yours has just came loose for some reason.
V-Twin... | Answered on Dec 24, 2014
This can happen if there was fuel left in the carburettor for a few months. The fuel forms a gel in the jets which can block the fuel getting through. You could try the following procedure which might help get it going.
  • Remove the sparkplug.
  • Pour about 5ml (or 1 teaspoonful) of fuel into the opening, where the sparkplug came out of.
  • Dip the end of the spark plug in fuel so the spark gap gets wet and replace the plug and HT lead.
Try to start the generator. The fuel that you poured in should ignite. This might be enough to get the engine running. You may have to repeat the procedure 2 to 3 times. Don't be tempted to pour too much fuel in as it will cause the engine to flood.
If the jets are blocked in the carburettor this might be enough to **** the fuel through but if not you'll need to get a mechanic to strip down the carburettor and clean the jets.
V-Twin... | Answered on Dec 16, 2014
sorry first time doing this..... 2 larger Grays to engine coils ( should be grays) 1 Larger Black to Ground above starter 1 smaller white with blue stripe NOT USED 1 larger White to Batt+ 1 smaller black with Yellow stripe to Ignition + or like on my engine straight to Batt+ i am taking it off and putting on switch because it does have a slight amp draw. Good luck hope it helps someone out there
V-Twin... | Answered on Oct 30, 2014
fuel pump not working or filter plugged
V-Twin... | Answered on Sep 07, 2014
Bad coil or flywheel is very suspect probably leaning twords flywheel
V-Twin... | Answered on Mar 02, 2014
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
124 questions posted
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Vehicle Parts & Accessories
Most Popular Question
gx620 engine am getting fuel
  • Vehicle Parts & Accessories
