20 Most Recent LG LRSC21935TT 36" Cabinet Depth Side-by-Side Refrigerator w/ 21 Cu. Ft. Capacity, Tall Bottle Dispe... Questions & Answers
Your water filter, if you have one installed, is located in the light housing of the top shelf. It is easiest to take your food off of the top shelf and remove the shelf to get easy access to it. I normally place a towel under it to catch any drips. If you do not see the canister hanging down then the bypass is likely installed. This is not a filter and can be used if no filter is desired. The "change filter" light will go off after a certain amount of time, or usage regardless if the filter,or bypass is installed.
LG LRSC21935TT... | Answered on Mar 06, 2019
The part you need is 3016JA2002B. Good luck
LG LRSC21935TT... | Answered on Jun 20, 2011
Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
LG Refrigerators | Answered on Jun 15, 2020
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
https://www.lg.com/us/support/help-library/error-codes-refrigerator-CT10000021-1441392048805
LG Refrigerators | Answered on May 11, 2020
It needs more gas. Call a refrigeration engineer.
LG Refrigerators | Answered on May 08, 2020
see if voltage to water solenoid if yes check line for blockage if ok bad solenoid if voltage to it if no voltage bad board
LG Refrigerators | Answered on Apr 16, 2020
Refrigerators Logo
11 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
lg model lrsc21935tt side side
  • Refrigerators
