20 Most Recent Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Questions & Answers
Remove any covers and physically look for the leak. Often is is just a case of tightening the bolts around the leak. Don't overtighten and strip the threads though.
Read this page of the manual. Look for leaks below it.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html?p=8
Troy Bilt... | Answered on Jan 29, 2018
It's not worth the expense and time, just purchase a new one.
Troy Bilt... | Answered on Sep 02, 2016
wheres the fuel ???
pluged line or carb may b
Troy Bilt... | Answered on May 15, 2016
NOT THE CLUTCH.. Mine started doing the same thing recently...what I found is the metal piece at the end of the main shaft that accepts the drive from the accessory was stripped out....the part from MTD/Troybilt is $60... Save the $60 its an easy fix....
Remove the sleeve at the end of main shaft.... clean thoroughly with brake cleaner...
Mix a small amount of JB Weld and fill along the walls of the "rounded out" area..Let set for about 2 hours so it gets firm but soft...
Take an attachment, and slide it up into the receiver..making sure to align them square with the receiver. this will form the JB Weld putty to the drive piece. remove the attachment immediately!!!.
Then let it set over night.... DONE works like a champ again next day.....
Troy Bilt... | Answered on May 06, 2015
Fuel jet may be plugged Not uncomon on small carbs. I had same problem replaced carb $19 from troy Built Problem solved
Troy Bilt... | Answered on Aug 13, 2014
no no no no no no no!!!
dont grind on a plug!! :D
Please get a new plug. Although there is spark - it is not enough to ignite the gas in the cylinder under load.
It is fine at idling because minimal gas is going into the cylinder.
Once under load (trigger pull) the gas/air mixture changes - and full spark is required.
Your engine is flooding because the plug is not igniting the gas.
Not only have you ground down the plug - but have also changed the spark gap.
PLEASE get a new plug, and be sure it is gapped correctly.
You did good cleaning the carb - but your problem lies in a $5.00 sparkplug.
Thanks for using FixYa !!
Troy Bilt... | Answered on Oct 03, 2013
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
Troy Bilt... | Answered on Sep 01, 2013
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Troy Bilt... | Answered on Aug 18, 2013
Go On Troy Bilt .com and you have to put the model number down then you can order a new one thats the best way
Troy Bilt... | Answered on Jun 19, 2013
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
161 questions posted
Top Troy Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
need replace fuel lines
  • Garden
