20 Most Recent
Husqvarna Forest & Garden 125l 18" Gas Trimmer Questions & Answers
Husqvarna troubleshooting
Test the coil with a spark tester. Also, clean the area behind the coil where it mounts. There must be good contact (ground) for the coil to product spark.
I have a Husqvarna 125L weedeater, New Fuel, has
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
My weedeater head won't spin.
Have you put the head on properly, is the drive shaft engaged in the gear head properly? What condition is the clutch in.?
How do you stop the
You either have your idle set too high or your clutch is worn/stretched springs
Have a 125l trimmer runs
Possible air leaking into the system. Also check the fuel tank vent, could be creating a vaccum in the tank.
