20 Most Recent Homelite Curved Shaft Trimmer Bump Feed Replacement Line Questions & Answers
Norma try Maturi's in Birmingham or Central spares
Homelite Curved... | Answered on Oct 01, 2013
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, @@
Homelite Curved... | Answered on Feb 23, 2012
You should wind it in the opposite direction of the head spin during operation.
Jim
Homelite Curved... | Answered on Aug 14, 2011
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Homelite Curved... | Answered on Aug 04, 2011
I,m no expert but you could try feeding it the oppisite way it spins. so i would say counter clockwise. if not it,s 50/50 it must be the other way
Homelite Curved... | Answered on Jun 28, 2011
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
Popular Tags
79 questions posted
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
spool cover need
  • Garden
