20 Most Recent LG LRFD21855 Stainless Steel French Door Refrigerator Questions & Answers
the drain sits on the backside bottom of the freezer.
the problem could also be that the freezer is to close to a wall and cannot get enough air wich causes a rise in temperature wich results in more water
LG LRFD21855... | Answered on Sep 25, 2017
CO error code means that there is a communications error between the display board and main board. Usually it's a connection problem. Just check to make sure the connections are still tight.
Good luck.
LG LRFD21855... | Answered on Jul 19, 2014
The same thing happened to my frig, also a french door model. I am told this is a known problem on my model MF 12568AES. I called Maytag on their 800 number, mentioned I knew this was a problem they knew about. They denied any knowledge of it, so I told them it was the high voltage board, the (2) 35w 680uf capacitors and they had a technician at my house within 2 days and although they didn't make that same board any more, they sent mine in for repairs. Over 30 days later it was re-installed and it works great. There was no charge for the service calls. My fridge is 8 years old. You can also read info from http://applianceguru.com/forum1/13035-1.html#ixzz2ghTCinxG. In there is a temporary fix until the board is repaired or replaced.
LG LRFD21855... | Answered on Jun 18, 2014
See this dent as character the price to repair is prohibitive however for cleaning I have the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more, even removes rust. Use on your windshield- nothing better for BUGS!!
We buy DeBruce at debrucepolish.com.
LG LRFD21855... | Answered on Mar 05, 2010
you can either on but i would suggest turning it off first just to be on the safe side
LG LRFD21855... | Answered on Feb 25, 2010
TRY USING A DENT SUCTION TOOL LIKE THEY USE FOR AUTO MOBILE REPAIR
LG LRFD21855... | Answered on Jan 10, 2010
Find one of those auto body dent dent repair guys. They are the people that can pull the hail damage dents out of cars. Its worth a try.
LG LRFD21855... | Answered on Aug 24, 2009
What you can try to do is put the ice maker in test mode. Press and hold the ice size button, on the ice maker itself, for 5 seconds. It should cycle through and this could reset it.
Sgt 48
LG LRFD21855... | Answered on Jun 02, 2009
You posted under an incorrect model number, so can only give general info. IF is a code for ice room fan. It is a fan located in a plastic box in the upper left hand corner of the freezer. The IF code shows up if the control board does not get a feedback signal from the fan telling the control board that the fan is running. I'd check to see if there is some ice blocking the fan blade. If that is not the case, you will need a meter to do further diagnostics to find out if your problem is with the fan motor or the control board. (note: when you turn the icemaker off, the fan will no longer blow cold air into the ice room, and all the ice will melt. Also, when the icemaker bin is full, the same basic thing can happen. Steady use of ice or dumping the bin will prevent ice from melting in bin.) The fan runs on 12 to 16 volts DC (variable speed), and the feed back signal is about 4.5 volts DC.
LG LRFD21855... | Answered on May 03, 2009
As you look straight at the white plastic square: Make sure the edge of the gasket is in place along the outer (in your case, left side) of the door. There is a metal spring near the white plastic square, and the end of that needs to be tucked into the groove of the door, not showing on the outside. Then, line up the white plastic square with the corresponding hole and use the palm of your hand to pop the gasket in, starting closer to the center of the door and working to the WP square area. (should only take about three hits.) Then, line up and snap on the long white plastic gasket retainer strip which runs from top to bottom along the inner edge of the gasket.
LG LRFD21855... | Answered on Mar 15, 2009
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
LG LRFD21855... | Answered on Mar 06, 2009
dent the other door to match
LG LRFD21855... | Answered on Nov 07, 2008
try and reset the door switch by pushing it down once or twice and confirm
LG LRFD21855... | Answered on Sep 02, 2008
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
LG LRFD21855... | Answered on Jul 22, 2008
cc82481.jpg The cause of the problem is here on the back wall, water gets trapped and freezes, over time a big ice ball will form. Defrost unit and cut off the insulation here, the water can now longer get trapped. Problem solved.
Sgt 48
LG LRFD21855... | Answered on May 31, 2008
maybe you purchased a kitchenaid upright deep freezer!
LG LRFD21855... | Answered on May 05, 2008
The electrical connector at the top of the hinge cover is not connected properly.  Pull the left hinge cover and make sure that the electrical connections are secure.
LG LRFD21855... | Answered on Apr 27, 2008
Sounds like it has a damper problem. If the damper is stuck in the open position cold air will continually flow into the fridge. Have to be careful diagnosing on these because most are controlled by a board and that could be the real problem. Need to check the damper motor for resistance with an ohm meter first.
LG LRFD21855... | Answered on Nov 17, 2007
LG LRFD21855 Stainless Steel French Door Refrigerator Logo
37 questions posted
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
er co not sure
  • Refrigerators
