20 Most Recent Pride New Mobility Rally 4 Wheel Scooter Questions & Answers
Need new brushes for motor
Pride's web site has them
9/3/2017 9:14:59 PM • Pride New... • Answered on Sep 03, 2017
Cannot remove covers from steering colum to fix forward controll.
Stearing problem smoke came out of colum
7/18/2013 9:00:57 PM • Pride New... • Answered on Jul 18, 2013
2answers
Rally 4. The steering seems to be stiff or tight.
hi,
ok now carefull tip the scooter onto one side, look at where the steering column attachs to the main frame, it's here you should find a bearing type collar, now you need to losen this and lubricate with a light gears, best to use a waterproof gease then tighting the collar up but
not too much otherwise your steering will again become tight.
Regards
GeWiz.
7/18/2013 2:35:19 PM • Pride New... • Answered on Jul 18, 2013
Scooter beep but wont run
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. Th is device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9 http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
7/29/2012 1:26:30 AM • Pride New... • Answered on Jul 29, 2012
As soon as i turn
please visit:www.alldatasheet.com & download-SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 Im disabled myself,hope this has helped.The site is free Colin.
3/10/2011 4:54:22 PM • Pride New... • Answered on Mar 10, 2011
Can I get a new Manual for the Rally 4 Wheel
Go to pridemobility.com
hope i was of some help
1/20/2011 1:30:03 AM • Pride New... • Answered on Jan 20, 2011
How do you remove the
the cover jest lifts off remove seat first
ted
11/14/2010 8:23:06 PM • Pride New... • Answered on Nov 14, 2010
Sometimes it goes well. other times it goes 20
henry how old is your scooter? If it is still under warranty you can call Pride Mobility @ 1-800-800-8586 to get it repaired. Now if it isn't under warranty and you personally paid for the chair then you will have to get it repaired at your expense. Now with the Pride Scooters there are problems with the cable that runs from the front console to the rear of the scooter because of all the stress placed on the cable. Since your problem is intermittent it could be a bad connection or a bad cable wire. Just check all your connectors at the rear of the scooter. You might try unplugging each one checking the pins and reconnecting them. Then try the scooter to see it that helped. If it didn't there isn't too much you can do to find the problem. Sorry I couldn't give you a better or definite answer. Good Luck
You might try contacting the provider that sold you the scooter and have them check it for you
10/21/2010 9:25:52 PM • Pride New... • Answered on Oct 21, 2010
How do i charge it up how will i know when its
hello,visit :www.alldatasheet.com .Type in the product you require info on & download it as a PDF File to read with an Adobe Reader.Batteries & how you charge them are important to go by the guidelines,im disabled & know they are not cheap.Also if your registered disabled,you can buy some things without paying the VAT.Please rate me as in thumbs up 1 to 4,as to how you feel i helped you.take care Colin.
9/17/2010 11:03:58 AM • Pride New... • Answered on Sep 17, 2010
When I power up scooter green light blinks, I have
hi i would change the key switch
8/9/2010 9:32:03 PM • Pride New... • Answered on Aug 09, 2010
I have a Pride Rally 4 Wheel Mobility Scooter
hello Carlos. Call the company directly at 800-800-8586 and they will provide you with the diagrams you seek. Joe
3/24/2010 3:09:03 AM • Pride New... • Answered on Mar 24, 2010
My pride scooter cam to a sudden stop and the
hi , so it cannot be push forward ?
if the freewhell function does not work, first look at the brake unit , see if you can remove it, normally about four to six allen bolts,
Now with the brake removed can you turn the wheels ?
If not then then it's most likely the gearbox so you will need to take it to a repair agent.
Regards
GeWiz.
1/3/2010 2:21:44 PM • Pride New... • Answered on Jan 03, 2010
2answers
How do you get to the batteries to replace?
The shroud is plastic that is held on by either velcro or screws.
8/22/2009 6:20:39 PM • Pride New... • Answered on Aug 22, 2009
2answers
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
6/13/2009 12:28:17 PM • Pride New... • Answered on Jun 13, 2009
Faulty speed adjustment control
Can you please tell me the Brand and model ?
6/13/2009 12:21:29 PM • Pride New... • Answered on Jun 13, 2009
Rally PRIDE 3-WHEEL SCOOTER
Sounds like you have a bad throttle pot. You`ll need to check the resistance on it or take it to a dealer.
4/1/2009 5:07:55 PM • Pride New... • Answered on Apr 01, 2009
2answers
Pride Go Chair, back wheels make noise when I go forward and reverse
It may be something as simple that you have picked up a twig or a piece of litter. Lie on the floor and look underneath with a flashlight or get a young person to do it..
3/5/2024 10:49:33 PM • Pride Health &... • Answered on Mar 05, 2024
Pride Mobility Victory 10 Scooter. What is the Viper blue color code for Pride Victory 10 please?
Question edited for clarity and toss in a load of CAPS. It is not published. You could ask them, or if you go to an auto paints supplier, they scan the paint on it, mix the paint and put into a spray can for you. https://www.google.com/search?q=Viper+blue+color+code+for+pride+victory+10+scooter ..
12/15/2023 1:32:36 AM • Pride Health &... • Answered on Dec 15, 2023
Pride New Mobility Rally 4 Wheel Scooter Logo
22 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
scooter beep but wont run
  • Health & Beauty
