20 Most Recent LG LRSC26910 Side by Side Refrigerator Questions & Answers
0answers
I have a LRSC26910 that compressor does not run. I
If it had a start cap it has to be in line with the start winding or it will never start.
10/7/2011 5:07:59 PM • LG LRSC26910... • Answered on Oct 07, 2011
Ice maker not working
Check water valve at back Its where the water line attaches to it.
Check water pressure
Pour a cup of water in the ice maker, if it ejects ice later then that
valve is probably defective
If it doesnt then the icemaker is defective
Also check temp of freezer should be below 10 degrees
If this was helpful please rate me.
Leo Ponder
[email protected]
8/17/2011 4:11:49 PM • LG LRSC26910... • Answered on Aug 17, 2011
Freezer not working digital
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
5/21/2011 5:39:55 AM • LG LRSC26910... • Answered on May 21, 2011
I have a american fridge
Check Ac power correct.
3/23/2011 12:57:28 PM • LG LRSC26910... • Answered on Mar 23, 2011
Ice maker over makes ice then ice cube tray cannot
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
1/3/2011 10:23:58 PM • LG LRSC26910... • Answered on Jan 03, 2011
0answers
The freezer dont work
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
9/5/2010 1:56:44 AM • LG LRSC26910... • Answered on Sep 05, 2010
My lg refrigerator's serial number comes back to a
Hello Todd. Go to Searsdirect.com and enter your model number, not the serial number and you will get a complete schematic showing all of the components. This will allow you to insure the correct model number.
Joe
4/4/2010 2:25:05 PM • LG LRSC26910... • Answered on Apr 04, 2010
2answers
The display turns off and the refrigerator stops working
There is only one thing that causing the problem. It is the main board.It costs about $90. Part number 1266870 and looks like this: 65badcb.jpg2d8e54c.jpg
2/26/2010 9:02:40 PM • LG LRSC26910... • Answered on Feb 26, 2010
Icemaker makes too few cubes
Find the water source for the ice maker(most are under the kitchen sink and are tapped off of the cold water line to the faucets) You need to either shut off the tap by turning it clockwise until it is closed. Then you need to disconnect the vinyl tubing from the valve. get a bucket and place it where it will catch the water from the tap. Gradually open the tap by turning it counterclockwise until water starts to come out of the valve. If you have a large enough bucket open the valve all of the way. If the stream of water does not change then the valve is bad and needs replacing. If the stream is nice and strong then the valve is ok. Turn the valve clockwise to close it, reattach the vinyl tubing and open the vale all of the way. This should improve the quanity of ice cubes. If not then there is a cripmp in the vinyl line between the tap and the solinoid valve on the back of the refrigerator.
7/18/2009 10:28:44 AM • LG LRSC26910... • Answered on Jul 18, 2009
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
5/16/2009 7:43:49 PM • LG LRSC26910... • Answered on May 16, 2009
The icemaker is not making ice, no water is getting through
Another user on this site is having a similar problem. What I suggested to that user is that they call the manufacturer before calling an appliance technician to see if there is a remedy for this problem in that it may be common with their product. Nothing beats saving money by making a free phone call. With that being said, I think the problem is in the solenoid of the ice makers. Water is getting to the solenoid but it is not turning on to allow flow beyond that point. It could be defective or it may be something as simple as trash or air in the line.
3/22/2009 4:21:10 PM • LG LRSC26910... • Answered on Mar 22, 2009
Water dispenser wont shut off
Something from the filter went into the dispensor valve and is holding it open. You can try to backflush it with a can of air by disconnecting the filter pushing open the valve while holding the can straw tightly while discharging it. You could also backflush it with water.
1/12/2009 2:04:03 AM • LG LRSC26910... • Answered on Jan 12, 2009
Water wont shut off
You have a problem with either a sticking dispenser switch or a sticking relay problem.  You will need to have a qualified LG technician diagnose the repair the problem.
6/8/2008 11:06:46 PM • LG LRSC26910... • Answered on Jun 08, 2008
No ice
There is a gauge of some kind which determines how much ice is in the trough. It is often an arm which is now raised out of that tray...Push it down.
12/21/2007 10:46:51 PM • LG LRSC26910... • Answered on Dec 21, 2007
LG LRSC26910 Side by Side Refrigerator Logo
42 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
display turns off refrigerator stops
  • Refrigerators
