20 Most Recent
Tanita BC550 Innerscan Body Composition Monitor Digital Scale Questions & Answers
My Tanita KD-300 is showing err6 - what should does it mean?
It seems that the error code "Err6" on a Tanita KD-300 scale indicates that there is a problem with the measurement sensors or the internal circuitry of the scale. This could occur due to a number of reasons, such as a buildup of dirt or moisture on the sensor, a loose connection, or an issue with the battery or power supply.
One potential solution is to try cleaning the sensor and making sure it is properly connected. If the issue persists, you may need to contact customer support or consider having the scale repaired.
It is worth noting that the Tanita KD-300 model is an older model, and some of the solutions mentioned in the search results may not be applicable to your specific issue. It is recommended to consult the user manual or contact customer support for more information on troubleshooting the issue.
My Tanita BC-542 when turned on shows88888
Check out this options.:--------
"Error" appears while measuring.
Please stand on the platform keeping movement to a minimum.
The unit cannot accurately measure your weight if it detects movement.
The Body Fat Percentage is more than 75%, readings cannot be obtained from the unit.
Your personal data has not been programmed. Try re-programming.
Make sure socks or stockings are removed, and the soles of your feet are clean and properly aligned with the guides on the measuring platform.Otherwise it shows error.
1. Select Personal Key and Step On
Press your pre-programmed Personal key.
(Release the key within 3 seconds or the display will show "Error".)
The unit will beep and the display will show the programed date.
The unit will beep again and the display will show "0.0"/ "88888".
Now step onto the platform.
If you step onto the platform before "0.0" / "88888"appears the display will show "Error" and Note:
you will not obtain a reading. Furthermore, if you do not step onto the measuring
platform within about 60 seconds after "0.0"/ "88888" appears, the power is shut-off automatically.
If any of the above mentioned options are incorrect then monitor will display error.This should help.Thanks.Helpmech.
