20 Most Recent Pride Luxury Line Maxima Scooter - 4 Wheel - Forest Geen Questions & Answers
Hi. Ring monster scooter parts the rear wheel assembly cost $132 dollars there is no mention on the front wheel assembly they might help U with more information 800-798-0325. ... Cheers
Pride Luxury... | Answered on Nov 24, 2016
Is the charger working? They do fail.
How old are the batteries? They have a lifespan of + - two years.
Has your main charger/ battery fuse blown?
Pride may tell you as they told me that it doesn't have one, nevertheless I found mine below the floor hatch under the foot mat ... and? It was blown. It's a standard 10 Amp car fuse, it cost a few cents and the problem was fixed.
The provider had said that it was definately my batteries and that he would replace them at €157.00 He didn't seem interested when I told him that they were already new! " One of them will be faulty then" he said.
Find that fuse, it's not in the tiller fuse box - but please don't forget that there is a risk of a power short or a bad electric shock be very careful and/ or get an electrician's help.
Pride Luxury... | Answered on Aug 02, 2016
Me too pls send me an email If you now where fond it
also do you have the manual ?
claude
[email protected]
Pride Luxury... | Answered on Jun 29, 2016
I just bought a Triton Products Ltd. electric three wheel scooter that has gone dead.We followed all the manual instructions but the electricity will not go from the battery to the controls Also I can't reach Triton Products Ltd. on any phone numbers they gave us.I'm 77 and need my scooter.
Pride Luxury... | Answered on Apr 01, 2015
You can get them anywhere batteries are sold. You need gel cell batteries that provide 30 amps at 12 volts. Check the numbers on the battery for proper height and width . You can get them on line too, but batteries are heavy so shipping will be high.
Pride Luxury... | Answered on Feb 24, 2015
That is hard to determine because of the variables such as your weight, the age and charge level of the batteries, the terrain condition such as hills, the roadway surface and the pressure in the tires if they aren't solid. You should get around 15 miles or so under ideal conditions.
Replace engager assembly, dial-a-speed pot and try again. These are common wear items (about every 3-6 years with or without use.)
If issue continues you have a bad controller... which is not common.
Pride Luxury... | Answered on Aug 11, 2014
hi, I do sell a light kit that fits into your charger socket,,, Look at www.rsrc.co.uk/cart or contact me on
www.gewizrepairs.co.uk
Pride Luxury... | Answered on Dec 30, 2013
3 to 4 hours
Pride Luxury... | Answered on Feb 27, 2013
I also have a Pride scooter that was given to me...how about that! Just go to their website and you can download the manual. Google the website. Just put in Pride mobility scooters.
Pride Luxury... | Answered on Aug 09, 2012
I see you checked everything but still the unit will not run at all.
Here is a link where you can as well download the Manual and information on how the wiring and assembly should be.
I check your concern, the only possible causes could be related to power I believe you mentioned that you already check all connections right, I guess it won't hurt to check the + and - Terminals have the correct cable to it, also make sure the both battery Harnesses are from both batteries are are plugged into their mating Harnesses leading to the charger.
Pride Luxury... | Answered on Sep 05, 2011
Is it a sealed lead acid scooter battery? Youcan get the replacement battery as per your scooters model number at http://www.monsterscooterparts.com/scooter-trickle-battery-chargers.html.All that you have to do is just search with the model number and you will getthe battery charger. Hope thiswill help you. Good Luck.
Pride Luxury... | Answered on Jul 11, 2011
hi.
there is a long list of things that could cause this problem.
if you have pneumatic tyres, make sure they are not soft. this can cause a lot of extra resistance, and cause overheating.
a dragging brake could could do this, but would be unusual. the brake unit would also feel extremely hot to touch if this is the case. you are more likely to have dry bearings on the wheels and transmission, or something wrapped (grass is common) around the axle. spin the front wheels to make sure they are free, and put the scooter in freewheel (lever or button on back of scooter) to do the same with the back wheels and axle.
another possibility is that the batteries are faulty. this can be confirmed with a battery load test which most garages can perform free of charge. the batteries should be fully charged for this and removed from the machine. a 100amp load test for 6-8 seconds should be enough for these batteries.
also make sure that any cooling fins and the area around the controller is clean and free from dirt that could prevent the unit from cooling properly.
another thing to check is that the weight limint for the scooter is not being exceeded. you will have to check the scooter manual for the exact weight limits.
these are the most common things that can cause this problem, and should be checked before doing any further tests.
please feel free to ask for further information if these steps do not resolve the problem.
hope this helps
Pride Luxury... | Answered on Jun 11, 2011
Pride Luxury Line Maxima Scooter - 4 Wheel - Forest Geen Logo
31 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
upgrade headlamp bulbs brighter ones
  • Health & Beauty
