20 Most Recent
Saunacore Standard Residential Sauna Heater Sau Sau Kw10.5std Questions & Answers
KW9B model, power to unit but no heat when timer
Heaters are pretty simple: when timer is on, voltage is applied to the heater elements until timer turns off. To troubleshoot your problem, use a multimeter or circuit tester to check the terminal connections on the heating elements themselves. With the timer ON, you should be able to read voltage (120 or 240, depending on your heater) at those connections. If you don't check the continuity of the wiring from your timer to your heater. Continuity w/out voltage at the element indicates a faulty timer, no continuity means bad wiring. If you do read voltage at the element but it isn't heating, your element is burnt out -- time to replace it. If it's a newly assembled setup or seems odd to be burnt out for some other reason, double check that you're using the correct voltage for that particular heater... 120vac won't run a heater rated at 240vac.
10/27/2010 6:09:01 PM •
Saunacore...
Answered
on Oct 27, 2010
My sauna wont turn on
check transformer. But always check for the obvious, plugged in? Burned fuse? Tripped circuit breaker at the panel?
I had a customer that had a 120 Volt unit plugged into a outlet that was not dedicated... That outlet was on the same circuit as her master bath outlets. One of the outlets had the GFCI buttons on it (little rectangular red & black buttons, newer ones today are both white: Test/Reset) anyway it was tripped. When it was reset, the sauna was working again.
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM •
Pool & Spa
Answered
on Mar 17, 2024
Virtual Pool 3. I need serial number for it please.
Free of charge from here. It is 23 years old, license expired.
https://virtual-pool-3.en.uptodown.com/windows
4.5/5 ยท My Abandonware
Description
Virtual Pool 3 is a 3D, first-person sports video game that simulates various cue sports, developed and released for Windows and PlayStation by Celeris. The game features 15 pool disciplines, snooker, and two varieties of carom billiards. Wikipedia
Platforms: Microsoft Windows,
PlayStation Portable,
Playstation
Initial release date: November 14, 2000
Mode:
Multiplayer video game
Genres:
Sports video game,
Simulation Game
Developers:
Celeris,
Digital Mayhem
Publishers:
Interplay Entertainment,
Sony Interactive Entertainment,
2K Play,
XS Games,
Gametapes LLC
Series: Virtual Pool..
1/10/2024 12:18:45 AM •
Pool & Spa
Answered
on Jan 10, 2024
