20 Most Recent Jandy AquaLink RS2/6 All Button Dual Equipment - Questions & Answers
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Jandy AquaLink... | Answered on Sep 03, 2017
not that I know need to replace or contact jandy and explain
Jandy AquaLink... | Answered on May 01, 2016
contact jandy tech support they will walk you through it
Jandy AquaLink... | Answered on Apr 30, 2016
check for cut or shorted wires at plug or wiring
Jandy AquaLink... | Answered on Apr 29, 2016
go into system setup go to freeze protection and un highlight that device
Jandy AquaLink... | Answered on Mar 05, 2016
contact manufacturer tech service and request a PDF file
possible loose 4 pin red connector or loose wire if ok bad bezel board
Jandy AquaLink... | Answered on Jan 30, 2016
no with an aux mark all auxes wich goes where unplug all then replace fuse hook up one at a time to see which one blows fuse then check that relay and wiring maybe motor shorting out or lights got water or bad wire
loose 4 pin connector or cut wire or wires touching at plug
go into system set up go to program highlight what you want either set or remove or edit program
go into system set up then go to program highlight what you want timed and set time on and time off
you tube or go into the system set up menu go to progams and make or take out
take off front cover of controller sometimes the buttons stick if ok need new display board
make sure 4 pin connector is plugged in also make sure wire isn't knicked or wires touching
if water sensor opened shows on heater then heater sensor bad if shows on aqualink the one on the pipe coming from filter is bad replace
Jandy AquaLink... | Answered on Jan 14, 2016
wires touching check 4 pin plugs then see if wires cut to controller
Jandy AquaLink... | Answered on May 28, 2015
check sensor and cell
check 4 pin connectors and see if wires been cut
go to system setup clear memory and reset aqualink board
Jandy AquaLink RS2/6 All Button Dual Equipment -  Logo
Popular Tags
57 questions posted
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
rogerpaul3
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Jandy Pool & Spa
  • Jandy Pool & Spa
Most Popular Question
jandy aqualink rs6 inside panel
  • Pool & Spa
