There are tow screw adjustments on the switch. One is the high shut off and the other is 'differential'. This is the one you need to adjust. It gives the 'window' that the system needs 'between' on and off. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Check for grass build up in the deck. You may have a bad bearing in the idler pulley or the blade hubs. bearings are likely seizing up. Sometimes it's due to the deck being set to low.
