20 Most Recent Teledyne Laars Laars Lx Nat Gas Pool Heater 250,000 Btu Questions & Answers
I have power into unit but the gas valve will not
check safety circuit first
11/6/2014 2:51:24 AM • Teledyne Laars... • Answered on Nov 06, 2014
Teledyne Laars Series 2 pool heater just clicks when the heater thermostat is turned on
check to see if voltage on both sides of pressure switch if so see if ignitor is lighting if ok check to see if voltage to gas valve should be 24 volts on each if no voltage check transformer also
11/6/2014 2:14:16 AM • Teledyne Laars... • Answered on Nov 06, 2014
I have a Laars lx250. I see 2 wires that come down to the heater pilot light. Running with then is a single wire that is black then has a small plastic peice then is white wire with copper strands. Th
white wires are to the safety circuit check the inside of the front panel it has a wiring diagram sounds like the wire goes to the fuseable link
11/6/2014 2:03:15 AM • Teledyne Laars... • Answered on Nov 06, 2014
I have a Laars LT250 pool heater. I went to start
I have repaired one like this and it is fairly complicated. I ended up replacing the control panel. That doesn't mean that is what will fix your heater. If you have a volt/ohm meter and call Laars technical support number they might be able to help you figure out what to do. I hope this helps.
Please vote on this answer. Thank you.
8/26/2011 2:49:06 AM • Teledyne Laars... • Answered on Aug 26, 2011
I need to replace the
The pilot ? or the thermocouple? or the igniter. Download your manual at:
http://www.laars.com/DOCUMENTDOWNLOADS/ProductManuals.aspx or main web address is www.laars.com
8/4/2010 1:31:16 AM • Teledyne Laars... • Answered on Aug 04, 2010
I have Teledyne Laars water heater model K250. The
USE THE OTHER ONE ALL THE TIME
10/13/2009 9:21:15 PM • Teledyne Laars... • Answered on Oct 13, 2009
Teledyne Laars LLG 250 boiler The pilot light goes out for no apparent reason any ideas why
Three basic possibilities - draught, insufficient oxygen available for the flame or interruption of the gas supply - most likely the latter. Quite likely the pilot flame is either not powerful enough to heat the thermocouple bulb, the thermocouple bulb is out of position and not being heated or the thermocouple is faulty.
5/4/2018 2:54:34 AM • Teledyne Laars... • Answered on May 04, 2018
I am looking for a service agent for a Teledyne Laars Mark V pool hearter in Melbourne Australia
Hi there Bernhard Siefert... (G'day) (from the other side of the date-line.. going out on the SF Bay today to watch our Blue Angels (again))... God Bless them...! ~~ Easy to do... (network search) Just search on your right combo... I used "Teledyne Laars spares service Melbourne Australia" and got (after wading thru a lot of SF malarkey) Spa Pool Gas Heater Repairs Service Conversions Maintenance Try it yourself ... your results will probably be better... http://www.ask.com/web?q=Teledyne+Laars+spares+service+Melbourne+Australia&qsrc=364&o=0&l=dir&qo=homepageSearchBox There are lots of heater questions and answers on this site if you were thinking about getting your heater running quickly... but if you are un-comfortable with tubing wrenches and GAS heaters... a qualified service technician usually SEEMS to be the safest approach. I've always done my own repairs... because leaving explosives in the hands of rookies and apprentices scares me... and life is good. Good luck... be safe!
10/9/2016 3:31:42 PM • Teledyne Laars... • Answered on Oct 09, 2016
0answers
0answers
Teledyne Laars Laars Lx Nat Gas Pool Heater 250,000 Btu Logo
Popular Tags
7 questions posted
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Oloyede Monsuru
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Teledyne Laars Pool & Spa
Most Popular Question
laars lt250 pool heater went start
  • Pool & Spa
