20 Most Recent Balboa Instruments Duplex Digital Panel 2 Pump Questions & Answers
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Balboa... | Answered on Feb 18, 2018
I have a Clearwater Spa with a LM8000 spa pack that the control module does not work. Can I purchase just the control module or do I have to replace the complete system? If I need to replace the complete system what system can I replace it with?
Balboa... | Answered on Jul 13, 2017
Check to see if something inside the control panel circuit board came apart or broke from being moved. These things were not designed to be moved around a bunch so you probably have a soder joint come loose or get disconnected.
Balboa... | Answered on Apr 19, 2017
there are at least two separate circuit breakers feeding your spa and two reset buttons. the circuit breakers are located a few feet away from the spa in an electrical box.
the reset buttons are in the mechanical space of the spa where the pump and heater are located.
Balboa... | Answered on Dec 29, 2015
Hello!
I have a question about my Balboy 500Z. When the water is heated the motor pump is still running that means the pump runs all the time without interrupt even the water has it's temperature. Now my question: is it possible to turn of the pump? thank you for your quick answer! Greetings Beat from Switzerland
Balboa... | Answered on Oct 23, 2015
The hot tub is in 'Economy' mode.
If you have a 'mode' button, press it until 'STD' shows. This will put the system back into the Standard mode.
If you don't have a 'mode' button drop me an email with a picture of your keypad and I'll try to advise you on what to press. [email protected]
Regards,
Ian.
http://hottub.synthasite.com
Balboa... | Answered on Nov 20, 2014
First, we have to establish what you mean by turn on the unit. Is the GFCI breaker set on when you try to turn the "unit" on? What are you activating to turn the "unit" on? A switch, a disconnect, a button on the topside controller, etc.? Need clarification before we proceed to diagnose. At what level do you understand electricity? Is there a licensed electrician available?
Please answer and we will take it from there. OK?
Balboa... | Answered on Jul 16, 2014
Switch the black & red wires, normally these are connected to the speed ports of the motor. But.... be careful! Electricity is color blind and does not care what color wire it is traveling through. So therefore confirm that the black & red wires are on High & Low marked lugs. Then once that is confirmed, then switch the position of those two wires.
Balboa... | Answered on May 27, 2014
good luck, post one if you ever find one.
bad element
Balboa Instruments Duplex Digital Panel 2 Pump Logo
139 questions posted
Top Balboa Instruments Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Balboa Instruments Garden
Most Popular Question
need replace
  • Garden
