20 Most Recent Jandy Lite2 Lj175n 175,000 Btu Natural Gas Heater Questions & Answers
Before you undertake this project, you should know that you will not just need the orfices. You will also need a different gas valve.
gas valve part number is : r0096900 for propane ($300.00+)
orfice part number: L0032900 (set of 2) ($3.00)
As you can see, this gas valve is not cheap. The lite2 is a very reliable heater, but chances are that if its been out of service, yo will also have to replace the thermocouple which will be another $75-$100.
Its very unlikely that anyone at your local pool supply store will have the gas valve in stock. They will definately not have the orfice in stock. Your best bet if you still want to proceed is to purchase these parts off the internet. Just google Jandy pool parts. then goto a few sites, search for the part numbers i gave you, and check for the best price.
Jandy Lite2... | Answered on Aug 10, 2011
DO YOU HAVE ALL THE WIRES CONNECTED? IF YES POWER MODULE MUST BE REPLACE
Jandy Lite2... | Answered on Oct 15, 2009
clean the filter first
I am now making more than 350 dollars per day by working online from home without investing any money.Join this link posting job now and start earning without investing or selling anything.
Follow Instructions Here........................ www.Worksbaar.com
Jandy Pool & Spa | Answered on May 16, 2020
I side the heat pump will be a small temp sensor mounted on the side of the inside area. Trace wire back and disconnect from control board. Replace the same way you removed the old one.
Jandy Pool & Spa | Answered on Feb 10, 2020
Make sure you have the correct version pda and antenna. The new 18 function white/black pda will not interface with the old gray antenna. Likewise, the new black antenna will only interface with the white/black remote.
Internal bypass rarely goes bad. More likely the high limit switches have corrosion on them and have failed. Pull the high limit switches out and see if there is corrosion on them. If there is replace both high limits and put a dab or white lithium grease on top before installing.
One of your actuators more likely the suction side is bad or the toggle switch on the bottom or side of the actuator is in the off position.
Jandy Pool & Spa | Answered on Jun 17, 2019
It is very likely that your exhaust Fuselink is faulty. There are two types of fuselink used on the LXI, commonly called the upper (exhaust) high temp and the lower (combustion intake) low temp. Make sure you purchase the correct part for the right location and ALWAYS turn off the power to the heater when changing the sensor.
Jandy Pool & Spa | Answered on Jun 12, 2019
Jandy  Lite2 Lj175n 175,000 Btu Natural Gas Heater Logo
Popular Tags
5 questions posted
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Marvin
Marvin
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Jandy Pool & Spa
  • Jandy Pool & Spa
Most Popular Question
bought used jandy lite
  • Pool & Spa
