20 Most Recent Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2 Questions & Answers
Code Fault Diagnosis Step Remedy
None
Open FC3 and/or
F1 Fuses
1. Check for faulty Gas
Valve wiring.
Inspect Gas Valve wiring. Ensure insulation on wiring is not worn. If
OK, proceed to step 2.
2. Verify that Gas Valve is
not defective.
Mesure for resistance across Gas Valve terminals and between each
terminal and ground. If short exists, replace Gas Valve. If OK, proceed
to step 3.
3. Check for faulty Control
Module wiring.
Inspect Control Module wiring. Ensure insulation on wiring is not worn.
If OK proceed to step 4.
4. Control Module is
defective.
Replace Control Module.
Ignition Failure 1. Ensure gas supply shutoff
valves are open.
Ensure that main gas shutoff installed adjacent to heater is open. Ensure
that knob on gas valve inside unit is in ''on'' position. If OK, proceed to
step 2.
2. Check for low gas supply
pressure
Ensure inlet gas supply pressure is between the minimum and maximum
values indicated on rating plate. If OK, proceed to step 3.
3. Check for faulty flame
sense wiring or connection.
Inspect flame sense wiring. Ensure wire harness terminals are securely
fastened to flame sense and to control module. If OK, proceed to step 4.
4. Check for faulty gas valve
Inspect gas valve wiring. Ensure wire harness terminals are securely
fastened to spade terminals on gas valve. If OK, proceed to step 5.
5. Check for gas valve
failure or gas valve relay
failure.
1. Measure voltage across gas valve during trial for igintion. If 24VAC
is present and gas valve does not open, gas valve is defective. Replace
gas valve.
2. If 24VAC is not present, gas valve relay on control module is
defective. Replace control module.
6. Check for blockages in
gas orifices and burners
Inspect gas orifices for blockages which could prevent gas flow. Remove
and inspect burners for blockage
Hayward H Series... | Answered on Jan 03, 2015
Sounds like it could be the flame sensor.
Hayward H Series... | Answered on Apr 07, 2014
There is a drain plug on the inlet/outlet header.
Hayward H Series... | Answered on Nov 02, 2013
Those particular heaters can be tricky because they came a few different ways, including a millivolt to electronic spark conversion that was done on site.
Your best bet is to get an old pool tech out there to see if they can get it fired up. The variables involved are far too extensive to troubleshoot in this format. Good luck with it.
Hayward H Series... | Answered on Jul 09, 2013
Your unit likely needs the control bezel assembly replaced. It includes the control pad and the circuit board it attaches to. We currenly have one in stock for $229.60 + shipping (and tax if shipped to a Michigan address). If you would like to order it please contoact us thru www.arrowpools.net.
John
Hayward H Series... | Answered on Feb 26, 2012
ROL would signify an open roll out safety switch. This is a small ceramic part with two wires plugged onto it and one screw holding it to the front of the burner compartment. This is there so that if the flame reaches the front compartment it opens and shuts down the heater to prevent burining up all the wiring and destroying the heater. This can be caused by a high wind while the heater is running, but can also be caused by a plugged up heat exchanger. It is an inexpensive part and easily replaced. Just be careful and always keep your face and body away from the front of the heater when firing it after doing repairs.
Hayward H Series... | Answered on Sep 04, 2011
If it is doing nothing then you need to investigate this with an electrical meter and find out where the power is not going...
The first place I would check is to see if you are getting power to the transformer...and then if 24v power is coming out of the transformer...
If this is happening the check the control module.. that is the next thing and is probably the bad part...
heatman101
Hayward H Series... | Answered on Jul 05, 2011
ErrorAO means BlowerVacuum Switch Open. If the blower prover switch does notclose after the blower starts the control will stop the ignition trial go intolockout. The blower will continue to run. Automatic reset is immediate afterthe switch closes. So you need to check this.
Hayward H Series... | Answered on Jun 15, 2011
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
Popular Tags
35 questions posted
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
year month manufacture hayward natural
  • Pool & Spa
