20 Most Recent Arctic Above Ground Rugged Mesh Winter Cover Pool Size: 18' X 40' Oval Armor 8 Yr Warranty Questions & Answers
4answers
Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
1/21/2018 4:20:59 AM • Arctic Above... • Answered on Jan 21, 2018
Error code PIER on arctic
There is no such code. PRR means a problem with the temp sensor. PRH means a problem with the high limit
1/21/2018 4:19:35 AM • Arctic Above... • Answered on Jan 21, 2018
0answers
Can I use my pool pump during the winter with a
That is not a problem. I've done it routinely on all types of pools.
10/27/2013 1:56:17 PM • Arctic Above... • Answered on Oct 27, 2013
Working on arctic spa, FLC
Sounds like a blown element. If there is no error codes and the heat symbol on the display is on you should read 240V across the two leads to the heater. If you have 240V its the element for sure. If not you have a bad board or heater relay.
3/24/2018 4:48:01 AM • Arctic Pool &... • Answered on Mar 24, 2018
2answers
Blew a hose and now the gfi breaker wont stay on,will stay on when i unplug pump to genius 3000 spa manager
need to test pump possible damage -- short --bearings seizing or binding--open winding s ---the pump is either pulling to many amps in an attempt to start or has a short causing the gfi to pop
3/24/2018 4:47:12 AM • Arctic Pool &... • Answered on Mar 24, 2018
2answers
A error message Free
Need info. Brand? Model?
1/21/2018 4:35:35 AM • Arctic Pool &... • Answered on Jan 21, 2018
2answers
What to do when you have a free message on your panel just filled the tub up
Need info on brand & model?
1/21/2018 4:34:29 AM • Arctic Pool &... • Answered on Jan 21, 2018
The waterfall valve is no longer working and we can't turn the waterfall off. Any suggestions?
Replace the valve. There were two types they used. For either of them pull the black knob off and you will see a cap under neath that un threads counter clockwise. Undo the cap and remove the valve. You can order them from Arctic or go to your local dealer
1/21/2018 4:33:33 AM • Arctic Pool &... • Answered on Jan 21, 2018
Where is the reset button on pump 1 on an arctic
If it is the old EMG pump that is green. The reset button is on the back off the black box on top of the motor. If it is not the Green EMG pump there is no reset and it is more likely the fuse in the pack that has blown
1/21/2018 4:26:25 AM • Arctic Pool &... • Answered on Jan 21, 2018
2answers
What does HL on display
Thank you for posting your question here on Fixya.com.
HL stands for high limit...it means one of the high limit switches is open, preventing the heater from working. Either the limit has failed and replacing it will correct the issue or there is a situation with the heater or flow rates causing it to truly overheat...fixing the issue will return the heater to operation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
1/21/2018 4:24:03 AM • Arctic Pool &... • Answered on Jan 21, 2018
After replacing the pressure switch, I still have
well, did you make sure switch is recieving enough pressure....or did u simply replace the switch? problem may not have been the switch in the first place
2/13/2014 6:52:15 PM • Arctic Pool &... • Answered on Feb 13, 2014
Reset pool pump
its called resetting your breaker or gfci
2/13/2014 6:49:30 PM • Arctic Pool &... • Answered on Feb 13, 2014
How to you replace the pressure switch on an arctic spa
First, locate the pressure switch and disconnect the wires that attach to it (they should just pull off). Now use another wire to connect those two wires, thus bypassing the pressure switch. If the problem continues, it is not the switch. If it works while in bypass, it is probably the switch, which just unscrews.Otherwise check to make sure that your water level is right and there are no obstructions in the filter or the suction line.
1/24/2013 5:33:18 PM • Arctic Pool &... • Answered on Jan 24, 2013
Arctic Above Ground Rugged Mesh Winter Cover Pool Size: 18' X 40' Oval Armor 8 Yr Warranty Logo
4 questions posted
Top Arctic Pool & Spa Experts
ADMIN Andrew
ADMIN Andrew
john h
David Spradling
David Spradling
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Arctic Pool & Spa
  • Arctic Pool & Spa
Most Popular Question
error code pier arctic
  • Pool & Spa
