20 Most Recent
Flotec 1/4 Hp Automatic Utility Pump Questions & Answers
Flotec FPUS1860A utility sink pump won't stop
Either the float is stuck or the float went bad...
give it a kick and make sure the float has dropped down and is not hung up...
If that don't work then unplug it and replace the float switch...
heatman101
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
I have a flotec fp512.
If the new foot valve is operting properly, then you must have a suction leak. If you can't find anything in the piping, then carefully re-inspect the check valve and where it attaches to the piping. If you still don't see anything, It is possible the pump seal is beginning to leak slightly when it's off, allowing air to enter the system. You could add another check valve near the pump, but it isn't necessary if all is working.
8/19/2010 3:35:41 AM •
Garden
Answered
on Aug 19, 2010
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
32 minutes ago
