20 Most Recent Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas Questions & Answers
0answers
0answers
Leaks
Be the first to answer 1/14/2016 6:59:19 AM • Teledyne Laars... • Posted on Jan 14, 2016Be the first to answer
0answers
0answers
When lighting my LG model
Thank you for posting your question here on Fixya.com.
The pilot generator most likely; if not there is a short in the gas valve and it will need to be replaced. Generators are a normal wear-and-tear replacement part...gas valves are not. The generator should be under $40 and is pretty easy to replace. Some places call the part the thermocouple but either name works. It is the metal 'stick' with a metal-clad set of wires from it the sticks up next to the pilot flame and is in turn heated up by the pilot to power the rest of the heater. If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
7/6/2015 11:37:51 PM • Teledyne Laars... • Answered on Jul 06, 2015
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
11/12/2014 2:46:00 AM • Teledyne Laars... • Answered on Nov 12, 2014
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
98 questions posted
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Oloyede Monsuru
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Teledyne Laars Pool & Spa
Most Popular Question
pool heater
  • Pool & Spa
