20 Most Recent
Raypak Versa 130,000 Btu Above Ground Natural Gas Heater Questions & Answers
Raypack pool/spa heater works intermittently
You can try pulling your pilot assembly out and clean it. Sometimes it will get sooted up and cause the sensor to short so the heater get's a falce reading and shuts the heater down. Then sometimes the heater will start and sometimes it won't. If this dosen't help check the ignition wire for any cracks or anyplace it may be shorting. Good luck.
Raypak Versa...
Answered
on Sep 25, 2010
My Versa Raypak heater will
A V HAWAIIAN POOLS INC
4085 WEST AVENUE L
LANCASTER, CA 93534
(661) 943-0557
31 miles
Directions
DENNIS RETTELA'S SWIMMING
11463 ORCAS AVENUE
LAKEVIEW TERRACE, CA 91342
(818) 896-4690
44 miles
Directions
VALLEY HOT WATER
4212 E LOS ANGELES AVE
SIMI VALLEY, CA 93063
(805) 526-5594
Raypak Versa...
Answered
on Aug 04, 2010
The heater does absolutely nothing when you turn
Unless there is water running out of the inside it is always repairable. You can start by pulling the burner tray and cleaning the unit and the burners. Also pull the wires and clean the leads and contacts. At 23 the heater is probally a milivolt run heater so a small drop in power can stop the heater from working. Often the problem will be the pilot generator or the gas valve. The generator should delevop 1/2 a volt to run the heater. This can be measured with a milivolt meter. You should get 500-700mv from the generator. If you get that and have no pilot you may need a gas valve and if not you probally need a new pilot generator and it would be best to replace the whole pilot assembly. If you live in Calif. or someplace that makes standing pilot obsolet you can probally find these parts on line through Ray-Pak.
But before starting check the filter to be sure it's clean. If you have had the pool for 23 years that goes without saying but I have to say it anyway.
After that you can use a jump wire and isolate each itim in the saftey circut (thermostat, high limits, presure switch...) just follow the wire when it leaves the gas valve and follow it to each item and jump across. If you find one of these itims to be the culpret it is just a simptom and their is probally another problem and the part just keeps the heater from working so as to keep it safe from that problem. Good luck and let me know what you find and we can go further if need be.
Raypak Versa...
Answered
on Mar 13, 2010
Pool heater works intermittently. have replaced thermostat kit
Depending on model you will need to ck ethier millavoltes (1/2 to 3/4 of a volt)or 24 volts. but this sounds like a pressure problem. Start by cleaning your basketsand your filter. If this dosn't help you should pull the presure switch from the manifold on the heater and see if their is any corrosen or rust on the sw or in the manifold. One of these should fix your problem. Good luck.
Raypak Versa...
Answered
on Nov 27, 2009
