20 Most Recent
Sta Rite Maxi Therm 400k Btu Propane Heater Questions & Answers
What r13 code mean
There is no r13 code on your heater. The r13 flashes everytime you turn on your heater, wait, then see if it fires, if not, you will get an error code starting with EO then a number, or the "service system" or "service heater" light will come on.
When i turn on sta rite spa heater , i can hear it
This is an ignition falure code. What you hear is the fan starting not the heater fireing. This can be a number of things and sorry to say but you should have a repairman out to look at the heater. The gambet runs from very frail parts to just plain dangerous and should have a qualified person check it out.
I use a small portable propane heater that has 6
Carbon monoxide poisoning !! do not use !! Get it checked for clogged intake air, as well as have burner checked and cleaned. Obviously running too rich, and intake air supply is getting cut off somehow.
Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Error AD0 SF0 180 r8
the stack flue sensor is bad make sure you order the identical part since is two model for thre same heater
What would cause heat exchanger to fail / leak
Usually poor pH maintenance. It can also happen quickly with improper chlorine tablets use; using a chlorine feeder or generator without a functioning check valve; or improper installation of a chlorine feeder or generator in general.
E01 fault and service light on
If you are still seeing the EO1 error code, turn over the display panel and see if there is a RED light next to a set of letters. Whatever the light is next to, that would be the cause of the error code.
