20 Most Recent Troy Bilt Pony 6.5 Hp Rear Tine Tiller Questions & Answers
sounds like one of the pressure switches is bad wire each direct one at a time to find out but do not leave it that way.
Troy Bilt Pony... | Answered on Dec 12, 2017
the roll pins should only need to be driven out with a punch they are hardened steel and would be hard to drill out anyway
Troy Bilt Pony... | Answered on Aug 13, 2012
you have a plugged jet inside the carb take it apart and clean them
Troy Bilt Pony... | Answered on Jun 25, 2012
How are you today? I hope well. This is a pretty simple project to get wheel off.
To remove tire & hub from tiller,place tiller on a secure jack or stand,remove front cap,behind wheel in hub & axle you will find a pin that goes through both,punch out with a punch or type of ice pick. You know something similar in your garage if you don't have a punch. Even a small Phillips screw driver could work. Of course when putting back on reverse procedure, might be able to use same pin if not damaged in process of removing it. Hope this helps, Mike
Troy Bilt Pony... | Answered on Sep 23, 2011
driving wheles for belts is not in line
Troy Bilt Pony... | Answered on Jun 03, 2011
Did you ever find a solution to removing your tiller wheel ? I have the same problem, tried pullers, heat, hammer, Wd40, everything. I would appreciate your input. Mike. [email protected]
Troy Bilt Pony... | Answered on May 27, 2011
I also was having issues with an old 5 horse Troy Built tiller that would fire when gas was in the tank then stop running. If it's a Briggs and Stratton engine like the one I have it's probably you can remove the muffler to gain access to the side of the carb. Remove the four screws and the cover off the fuel pump diphram and check to make sure that the rubber isn't cracked or degraded. I replaced the one I had and it now runs like a champ.
Troy Bilt Pony... | Answered on May 23, 2011
Not a problem ...
Troy Bilt Pony... | Answered on Apr 02, 2011
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Troy Bilt Pony... | Answered on Oct 07, 2010
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
106 questions posted
Top Troy Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
am currently looking
  • Garden
