20 Most Recent Interactive Health Ijoy 130 Massage Chair Questions & Answers
2answers
Just sits and shudders when you push any button except the up and down button
HI, mine started doing the shuddering. It would roll OK, but shudder when the massage part kicked in. I took it apart. There is a plastic gear on the shaft at the bottom of the massage motor. It has a broken tooth. I called the support number for human touch: (800) 355-2762 and they only sell all the mechanical guts as a package for $125.00. I'm still looking for just the gear but am having no luck.
11/22/2022 5:35:10 AM • Interactive... • Answered on Nov 22, 2022
Hi. I have an Ijoy 130 and I can't get the roller to come back up. Motor runs and you see wheel turning on the motor, but the rod (or huge screw thing) that extends from the top of the chair to the t
Exact same thing happened to mine. Took it apart and found the rod is severed. When I called the manufacturer, they said they don't sell parts and is past the 1 year warranty. So I'm completely out of luck. Were you able to find a solution?
3/26/2019 9:42:03 AM • Interactive... • Answered on Mar 26, 2019
Replacement Upholstery
I have the same problem. Did you ever find something?
4/9/2017 2:57:57 AM • Interactive... • Answered on Apr 09, 2017
The massage function stopped working, it still
Better to see a specialist about massage chair. You can use a vending massage chair by the time it get fixed.
7/30/2015 5:53:30 PM • Interactive... • Answered on Jul 30, 2015
Can you force the ijoy board to operate without the infared remote? Mine is gone and the manufacturer no longer makes them.
I would hardwire it to a switchbox that controls the motors seperately.
6/30/2014 9:36:40 PM • Interactive... • Answered on Jun 30, 2014
0answers
3answers
I hv a Interactive Health Chair #HT-270.
AS if the light in the remote is blinking ,that what you mentioned .then there can be only two problems
1)The battery in the remote is got weak .so replace the battery.and check out many a times the problem gets solved.
2)and the other confirm problem is.There is a control board in the chair .on the control board there are many components .but the most common component is the control power IC.The number of the IC is IC498YU and exactly beside that ic there are two resistors the number of the resistor is r79 and r73.this there things has to be checked and replaced the cost of the IC is near to $6 and the cost of both the resistor is near to $1.if you are not familiar with technical knowledge then get it done with proper repair person.a repair person who is very much familiar with using soldering iron and multimeter will be more then enough.
-----------BUT first replace the battery of remote and check out,before doing any reparing.if that does not helps then gop for the reparing.--------- also check out any loose wiring connection in the control board area.------------
please do rate the solution.
thank you for using fixya.keep updated.thanks.
8/9/2010 1:36:22 PM • Interactive... • Answered on Aug 09, 2010
I want to purchase a replacement gear for my iJoy
try target
3/6/2010 6:08:45 PM • Interactive... • Answered on Mar 06, 2010
Interactive Health Ijoy 130 Massage Chair Logo
Popular Tags
35 questions posted
Top Interactive Health Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Interactive Health Furniture Expert? Answer questions, earn points and help others
View Most Popular
  • Interactive Health Furniture
Most Popular Question
just sits shudders when push any button
  • Furniture
