20 Most Recent Dewalt Heavy - Duty 5" Random Orbit Sander - D26451 Questions & Answers
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Dewalt Heavy -... | Answered on Nov 19, 2018
remove pad and clean and lube cam
Dewalt Heavy -... | Answered on Nov 11, 2009
Could be a defective switch
Dewalt Tools &... | Answered on Dec 05, 2019
Fixya is unable to suggest sources for the seal you seek.
Dewalt Tools &... | Answered on Nov 04, 2019
The nailer must be firmly pressed against the surface you are planning to nail. This will arm the nailer in preparation for firing the nail.
Dewalt Tools &... | Answered on Oct 03, 2019
Try this link:
https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
Dewalt Tools &... | Answered on Apr 02, 2019
no, but there may be an overload fuse. My guess is that it is part 62 here, but not available. Take it to a DeWalt service centre
https://www.ereplacementparts.com/dewalt-dw431-type-electric-belt-sander-parts-c-1009_2742_2764.html
It is available here, but is $88. Lot of money to lay out on a guess, which is all the more reason to get it looked at professionally. It may also be the motor windings burned out.
https://www.toolpartsdirect.com/dewalt-dw431-type-5-electric-belt-sander.html
Dewalt Tools &... | Answered on Feb 27, 2019
Either the blades are incorrectly installed causing the head to jam or the safety cover is not installed properly - there is a safety mechanism that locks the cutter head when the cover is removed.
Dewalt Tools &... | Answered on Feb 02, 2019
Typical cause is low voltage - but can also be a bent driver or something jammed in the nail track.
Is this a finish nailer or framing nailer?
That symptom usually indicates a low voltage issue - not sure how the adapter may affect this, I've never run them with a 20v battery.
Try it with a standard 18v and see if you have the same issue - please comment back with the results, I'm curious.
This is a common problem with this compressor and still is a problem in 2014.It is under powered and trips the reset
Dewalt Tools &... | Answered on Feb 01, 2019
copy and paste in search engine. took about 5 seconds to find answer.
Dewalt Air Compressor D55146 Belt Replacement
Dewalt Tools &... | Answered on Nov 23, 2018
Dewalt Heavy - Duty 5" Random Orbit Sander - D26451 Logo
2 questions posted
Top Dewalt Tools & Hardware - Others Experts
John Trevino
efs_perpends
efs_perpends
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Tools & Hardware - Others
Most Popular Question
dewalt d26451 type 1 random orbital
  • Tools & Hardware - Others
