20 Most Recent Craftsman 4 Cycle Blower/Vac Questions & Answers
It could be something as simple as adjusting the carburetor. (if you have the adjusting tool) otherwise it sounds like there may be some debris in the carburetor. After running for a little while, it blocks the fuel jet. Then when you shut it off, it falls back somewhere in the carburetor. I'd suggest cleaning the carburetor and draining the fuel out and putting new gas in.
Craftsman 4... | Answered on Dec 15, 2017
I have craftsman 25cc 2-cycle blower-It wont turn over-I put new spark plug and cleaned filter. It dosen"t seem to be getting any gas. How would I know if its the gas filter and how do I put new one on? thanks,mh
Craftsman 4... | Answered on Nov 26, 2016
Before you start take a picture of where the old lines are connected to the carb and the primer bulb for future reference.
To replace the line pull the spark plug wire from the plug. Remove the old line from the tank and remove the fuel filter from the line. Take new larger line and cut it on a 45 degree angle/or trim as necessary so you can grip it from inside the tank and pull it into the tank. Perform the same operation on the smaller line as well. Be sure to leave enough line for the fuel filter to reach the bottom of the tank. Install the fuel filter. The other small line is a vent line and only needs to come inside the tank not go to the bottom in the fuel.
Good luck.
Craftsman 4... | Answered on Nov 22, 2016
That is actually a good price. MTD wants $225.00
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Craftsman 4... | Answered on Nov 02, 2016
Go to searspartsdirect.com and enter the model number and it will give you a diagram for the carb. Hope this helps.
Craftsman 4... | Answered on Oct 09, 2016
I have a craftsman 25cc blower. It is not getting fuel in the cylinder. I replaced gaskets and even the carb, no luck. When i took off the intake to replace the gasket, i pulled the start line and noticed the piston does not drop far enough to allow fuel in the cylinder.
Craftsman 4... | Answered on Nov 20, 2015
Similar experience with the same blower. I cleaned the carb checked for spark but I still can't get it to start
Craftsman 4... | Answered on Dec 10, 2014
The low is the one closest to the crankcase
Craftsman 4... | Answered on Jul 28, 2014
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
Craftsman 4... | Answered on Dec 24, 2013
Make sure you have the right mixture of oil and gas. mixtures to rich will plug up the filter
Craftsman 4... | Answered on Nov 21, 2013
Thin line is the fuel intake and is attached to the fuel filter. The other is the return, and should be placed on the tube below the primer bulb of the carburetor.
Craftsman 4... | Answered on Oct 18, 2013
Could be low engine compression. Change gaskets, piston & cylinder.
Go to sears.com and print it out.
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Replace gaskets,piston & cylinder.
Craftsman 4 Cycle Blower/Vac Logo
207 questions posted
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
start gas spark craftsman leaf bower
  • Garden
