20 Most Recent Swisher 52" 20 Hp Riding Lawnmower #Zt2052 Questions & Answers
3answers
I would like to change the front tires lawn mower
Remove the wheel from the mower.
Let all the air out
Lay the tire flat
Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
Apply soapy water to the tire and rim
Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
go
Repeat the last step for the other side of the tire, same side of the rim though!
Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
4/18/2019 7:51:01 AM • Swisher 52" 20... • Answered on Apr 18, 2019
I HAVE A GT245 JOHN DEERE LAWN MOWER WITH A 20HP
Get the carburetor adjusted
2/20/2018 6:58:12 PM • Swisher 52" 20... • Answered on Feb 20, 2018
Countax c400h with honda v twin engine over fueling problem.
my guess would be a carburetor adjustment as it sounds like it is burning to rich. if there are no set screws i would replace the needle and seat.
11/25/2016 5:09:33 PM • Swisher 52" 20... • Answered on Nov 25, 2016
My John Deere 60HC mower deck keeps falling off on hilly terrain, what do I need to do to prevent this?
Check tyre pressures and make sure they have sufficient tread, sit as low as possible
5/13/2014 1:27:32 AM • Swisher 52" 20... • Answered on May 13, 2014
I have an A680L John deere riding lawnmower. The
Burning belts sounds like something is locked up. Make sure there's nothing wrapped around any of the blades and that they turn freely.
9/9/2009 11:07:27 PM • Swisher 52" 20... • Answered on Sep 09, 2009
Model LS722 swisher what kind of oil
1/25/2023 5:08:05 PM • Swisher Garden • Answered on Jan 25, 2023
Where to find hydrostatic pumps
Likely its a hydro-gear, available from multiple sources.
9/23/2022 1:16:11 PM • Swisher Garden • Answered on Sep 23, 2022
I have a Swisher 2560 zero turn riding mower that when I ride to cut with it it hops I don't know why if anyone can help please
Swisher ZTR steering arm is a poor design and loosens over time which eventually causes control issues. If the steering arms flop about, the main pivot bolt needs tightened.
4/13/2022 10:05:13 AM • Swisher Garden • Answered on Apr 13, 2022
Replaced the blade drive belt on my Swisher Finishing Touch 42" walk behind. Now that the new belt is installed, I turned the mower on and the pulley that spins the blade drive belt is not spinning.
It sounds like the belt was installed wrong or not adjusted assuming it is the correct replacement.
10/2/2021 2:34:42 AM • Swisher Garden • Answered on Oct 02, 2021
Can a bad battery cause clutch to slip?
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
10/17/2018 1:38:52 AM • Swisher Garden • Answered on Oct 17, 2018
Swisher 52" 20 Hp Riding Lawnmower #Zt2052 Logo
Popular Tags
16 questions posted
Top Swisher Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
View Most Popular
Swisher Garden
  • Swisher Garden
Most Popular Question
countax c400h honda v twin engine over
  • Garden
