20 Most Recent
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Questions & Answers
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your
pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
- Low water levels
- Dirty filters
- Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
How to change water pump
Don't change with a like product from Intex - they are a toy.
Get a real pool pump - spend a little more $$$ and you will be so much happier with an upgrade.
The pump is not pushing water through. Wat is the
ure the propeller and shaft turn, but I woulsd dare to say that they are actually turning independant of each other. Sort of like a stripped nut on a bolt. They both look like they are in place and working, but when you add any sort of pressure they just don work the way that they are supposed to. I bet the shaft is actually spinning inside of the propeller, as soon as the water pressure is built up, it fails. Spinning it with your fingers will not imitate the real life pressures exerted on the propeller and shaft, that the water pressure exerts under load (in operation). I would either rebuild it with new parts (new shaft and Propeller) or just go out and buy a new one with a warranty. There is no other reason why this pump will jnot throw water through your system... NO REASON, unless you have the thing hooked up wrong, but I think that would be impossible, wouldn't it?
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your
pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
My intex pool filter is constantly leaking and we
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
