20 Most Recent Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer Questions & Answers
3answers
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
10/19/2018 8:14:15 AM • Arrow... • Answered on Oct 19, 2018
2answers
Instruction book for Arrow ETF50P staple gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
3/18/2017 6:22:19 PM • Arrow... • Answered on Mar 18, 2017
0answers
0answers
Jammed
Be the first to answer 12/8/2013 3:21:23 AM • Arrow... • Posted on Dec 08, 2013Be the first to answer
0answers
0answers
Schematic ET50 red
Be the first to answer 3/21/2013 12:53:25 AM • Arrow... • Posted on Mar 21, 2013Be the first to answer
0answers
I have an Arrow ETF50P
Be the first to answer 10/28/2010 10:45:35 PM • Arrow... • Posted on Oct 28, 2010Be the first to answer
Got a staple jammed can't get out . don't know to
This can happen all the time... first remove the slide-in tensioner which pushes against the staples. Remove the single bolt with lock nut which is towards the rear of the stapler. Now you can pivot the staple rail down and out of the gun. Just remove any twisted staples from the rail. Now reassemble the rail by positioning the front of the rail to go into the small slots in the front of the stapler body and re-attach the bolt. You may now reload the staples and tensioner and continue working. Takes just a minute or 2.
7/10/2010 12:53:50 AM • Arrow... • Answered on Jul 10, 2010
How do I load staples? I can not find my manual!
On the back bottom of the stapler there is a rod you need to lift up and then pull out on it should come out
12/2/2009 12:12:20 AM • Arrow... • Answered on Dec 02, 2009
I cant get the rod out to put new staples in
These things are weird. What you gotta do is push on the end and lift it up and then pull. Jiggle it around like you would trying to get a key to work. Good luck!
9/20/2009 4:17:58 AM • Arrow... • Answered on Sep 20, 2009
The door at the back of the staple gun won't close
You may have too many staples loaded in the magazine.
6/9/2009 7:36:11 PM • Arrow... • Answered on Jun 09, 2009
Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer Logo
25 questions posted
Top Arrow Tools & Hardware - Others Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Arrow Tools & Hardware - Others
Most Popular Question
instruction book arrow etf50p staple gun
  • Tools & Hardware - Others
