20 Most Recent
Porter Cable Gravity Feed Paint Sprayer Questions & Answers
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
Porter cable PSH 1 -
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Porter cable air nailer leaking
It certainly sounds like you may need to replace the seals on the tool.
The two main culprits are loose screws or bad seals.
Try tightening all the screws on the unit.
If that doesnt fix then you will need to purchase an overhaul kit for your model or take to a repair shop.
Since you did not give me your model #, Here is link to locate necessary parts:
http://servicenet.deltaportercable.com/Thanks
Is a porter cable fr350 the same as fr350a?
The fr350a is completely different from fr350. The fr350a is completely modernized framing gun as compared to the retired version. I do not like repair kits because you are replacing parts that are still good. Instead replace parts as needed. If you state the issue you are having I may be able to recommend the actual part needed. If however you do not have any major air leaks, a lube job will make the gun work great. Use white grease or nail gun oil. Good luck with your repair.
Porter Cable Brad Nailer - Firing without pressure
The nose tip is most likely stuck in the ready to fire position from too much force being applied when nailing. These guns are small and sensitive to forces being applied. Try bumping it to see if the nose tip is retracting and compressing with each bump. Unplug and unload the gun before trying to pull the tip of the nose to retract if it is stuck. Check for foreign objects obstructing the trigger and safety mechanism
