20 Most Recent Pride Mobility Victory 3 Wheel Electric Scooter Questions & Answers
Buy kamagra gold 100 Online is used for Enlarged prostate gland in male, Increased blood pressure in lungs and other conditions. Know about the uses, side effects, price, composition, substitutes, How it works, Lowest Price Online. Kamagra Gold 100mg Online buy with lowest Price Ever Online Pharmacy. Kamagra Gold 100mg Reviews.
Pride Mobility... | Answered on Feb 27, 2019
right, what scooter is it, You can try putting it in reverse slowly and that will bring your scooter to halt then reverse so take care, what brand and model of scooter ? Regards GeWiz
Pride Mobility... | Answered on Oct 02, 2017
Piggies might fly = Pride don't want you to go anywhere near one.
Pride Mobility... | Answered on Aug 02, 2016
Is the charger getting power? Is the power reaching the battery pack to charge them? If you answer yes to both questions then something has to be wrong with the battery pack.
Pride Mobility... | Answered on Jul 25, 2015
there may be a loose bolt, I would see if someione you know has any mechanical ability and may be able to fix it easily or tell you what it needs.
Pride Mobility... | Answered on Jul 14, 2015
hi, well how old is the V10 ? please remember a pair of batteries is only as good as the charger...
Regards
Rob
www.gewizrepairs.co.uk
Pride Mobility... | Answered on Jul 10, 2015
The motor has 2 brushes under a circular cap on the sides of the motor. When they wear down, they can use more current. Look there first. Then move on to the brake unit that is connected to the motor. If it doesn't release completely then excessive current will be drawn to move the scooter.
Pride Mobility... | Answered on Feb 24, 2015
I have the same prob ! Try thses, I have cleaned the carb, ive checked for a spark (yes), cleaned fuel tank and checked to see if it is getting fuel and it is, also reset the air/fuel screw 1 and a half turns to factory reset NOTHING :( and took spark plug out and put my thumb over the hole pulled the pull start and it feels like it has pressure.
Oh and yes I did put 2 stroke oil in the fuel !
Pride Mobility... | Answered on Feb 19, 2015
Needs a full overnight charge of at least 12 hours and left on charge even when the lights tell you it's is charged up.then get into the habit of running it right down to improve the storage stamina of battery.good idea to take charger out with you so if you get a chance to top it up somewhere whilst away from home.remember in cold weather these things can't travel as far.
Pride Mobility... | Answered on Dec 09, 2014
You need to adjust the tow in. There is adjustment underneath.
Pride Mobility... | Answered on Nov 25, 2014
lift dust boot on the bottom section of the yoke below the fiberglas covers and the yoke tilt adjustment, the adjustments are located at this nifty hiding place
Pride Mobility... | Answered on Aug 27, 2014
Your motor and/or brake is more than likely bad.
Pride Mobility... | Answered on Aug 26, 2014
either a battery or cable problem long stretch would be breaker and lastly motor if cables get hot try replace them first with larger wire sounds like a resistance problem assumeing your batteries are good and motor brushes good
Pride Mobility... | Answered on Jul 02, 2014
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Pride Mobility... | Answered on Apr 29, 2014
check your charger - or your battery or both - my thought is the charging unit failed and is not charging to full battery
Pride Mobility... | Answered on Apr 05, 2014
Pride Mobility Victory 3 Wheel Electric Scooter Logo
77 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
pride victory 10 4 wheel increase
  • Health & Beauty
