20 Most Recent Pride Revo 4 Wheel Scooter Questions & Answers
1 dud batteries?
2 dud charger? Borrow another
3 has a 10 Amp fuse hidden under the floor mat and inspection hatch below blown. Pride don't want to tell you about thevtwo fuses down there.
Pride Revo 4... | Answered on Jun 02, 2016
You are almost certainly going to have to lift the seat off its post as you do with other Pride scooters. This is not light and it can be sticky and need tobe wiggled off - get help.
The shroud is usually velcroed into place and can easily be detached. Lift it off and put safely to one side.
Hope its this. Batteries fully charged. You should take to dealer. I bent my go lever. I bent it back alittle. There is little switches under the cover, they can moved. Lever is not make proper contact
Pride Revo 4... | Answered on Jan 19, 2015
No Well maybe If you remove the console cover and see how the throttle is mounted to the tiller. If the throttle pot and handle are screwed to the tiller with two screws you might be able to unscrew the throttle assembly and flip it upside down letting you use your left thumb to push on the throttle. Unique problem because if you can't flip it then you are stuck pulling the throttle reverse side outward to make it go forward. Hope this helps you might even have to flip the throttle lever ( take it off the throttle pot and flip it and reattach to the pot stem) so it will fit back under the console cover. I dunno for certain but you can try
Pride Revo 4... | Answered on Sep 16, 2014
there is a bearing inside pin roller this get no grease unless pulled apart and serviced so if this has not been done the bearing is most likely worn out take apart and find bearing number very small ### so wash in solvent to see it go to auto parts store and order new 1
Pride Revo 4... | Answered on Oct 23, 2013
I have wiring chartfor Revo if your interested
Pride Revo 4... | Answered on Dec 12, 2012
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Pride Revo 4... | Answered on Jun 13, 2012
Is the noise like a stone stuck in the tyre? If so, I think you have a dry axle, a common problem with Pride scooters and easily rectified. Simply remove the rear wheels, apply grease to the axle shafts, and re-fit the wheels. This should solve your problem. If it's a different type of noise, the problem may lie within the transaxle which would unfortunately involve a costly repair or most likely a replacement transaxle.
Pride Revo 4... | Answered on Sep 27, 2010
The one thing that wouldn't cause the noise is the batteries.
If it is an electrical noise, it will be the speed controller as they go slower in reverse than in forward.
If it is mechanical, it might be the brake or the motor drive. Take it to your local dealer for correct diagnosis and repair IF needed.
Pride Health &... | Answered on May 20, 2020
https://www.youtube.com/watch?v=J2gB3FGUJXc
A lot of times when the mobility scooter cuts off, the gauge on the battery drops to zero. ... The most common reason for a fast-depleting battery is age. As batteries age, they store less charge and are less efficient. So not only do they lose their charge faster, they have little of it to begin with.
https://activeseniorsclub.co.uk/mobility-scooter-keeps-cutting-out/
Pride Health &... | Answered on Apr 17, 2020
8 flashes means there is a power module issue. Check the connections at the battery and power module. If ok, check the battery, it may need replacing.
Pride Health &... | Answered on Jan 28, 2020
ow To Fix Your Scooter That Won't Turn On Or Charge - YouTube
https://www.youtube.com/watch?v=rgK2l6cMCc4
17 Mar 2017 ... GoGo Or Go Go power chair repair. How to replace the batteries in the sealed battery box on your power chair scooter. Battery: UB12180.
Pride Health &... | Answered on Jan 24, 2020
One light flashing means: The batteries need charging or there is a bad connection to the batteries. Check the connections to the batteries. If the connections are good, try charging the batteries.
Pride Health &... | Answered on Dec 24, 2019
hi Peter at worse, ,sounds like a controller fault, are you uk based?
could be that the motor brushes are causing the fault.
If so i can repair them from £20.
regards
Rob
Pride Health &... | Answered on Dec 22, 2019
The flashing light is flashing a code that indicates an electrical problem. See your manual for the codes on pg 38.
Pride Health &... | Answered on Dec 14, 2019
Pride Revo 4 Wheel Scooter Logo
11 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
rear axle fortress 2000 scooter moves
  • Health & Beauty
