20 Most Recent
Golden Technologies Avenger 3 Wheel Electric Scooter Questions & Answers
Battery fully charged,horn works but
Make sure your freewheel brake is in the DRIVE position. Check your owner's manual for the location of the free wheel lever, ususally it is near the rear of the scooter. If the chair is in DRIVE mode but the wheels will not turn, you may have a motor problem which would require replacing the motors.
2/2/2016 5:09:41 PM •
Golden...
Answered
on Feb 02, 2016
Golden avenger goes very slow with good batteries
hi,
ok so you're sure the batteries are ok, and the charger is charging the batteries ,
check the battery connections on the terminal are not loose , they must be tight but don't overdo it,
are the brushes ok ? do they move ok within the motor ? sometimes they can stick therefore you lose power and speed,
Lastly but can cause problems is the speedpot, does it have a lot of up and down movement ? you will be suprised the problems they can cause.
~Regards
GeWiz.
12/5/2009 10:13:37 PM •
Golden...
Answered
on Dec 05, 2009
Sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
3/9/2009 7:50:20 PM •
Golden...
Answered
on Mar 09, 2009
