20 Most Recent Epiphone Aj-100 Acoustic Guitar Questions & Answers
That depends on which way the neck is bent. Tighten if bowed away from the strings, loosen if bowed toward the strings. Go only a little at a time letting the neck settle as you go. If not familiar with the procedure you can cause damage to your guitar. I sugget taking it to the shop.
Epiphone Aj-100... | Answered on Jan 02, 2015
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Epiphone Aj-100... | Answered on Jul 25, 2013
Request the wiring diagram directly from Epiphone.
Epiphone Music | Answered on Sep 04, 2020
Your guitar was made at the Kalamazoo Plant, MI, USA
between 1962 and1964, most likely in 1962.
Epiphone Music | Answered on Aug 02, 2020
Korea, 1996, July as best as I can make out from https://forum.gibson.com/topic/139846-epiphone-serial-number-decoding/
without knowing the model and the condition, there's no telling what it's value is. Check reverb.com for similar guitars
safe to say tho that a Korean made Epiphone is not a classic (pre-Gibson) and will not be a high value guitar.
Epiphone Music | Answered on Nov 02, 2019
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Epiphone Music | Answered on Sep 11, 2019
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Approx 1965. Cant determine value without model #
Epiphone Music | Answered on Aug 21, 2019
Possible manual from manufacturer web site found using https://www.google.com
May be a different model than yours.
http://images.epiphone.com.s3.amazonaws.com/Media/Manuals/EpiOwnrsManul.pdf
Epiphone Music | Answered on Aug 13, 2019
Epiphone - The Guitar Dater Project - Epiphone Serial Number Decoder
https://www.guitardaterproject.org/epiphone.aspx
The Epiphone serial number decoder currently supports 12 serial number formats from 25 factories. Vintage numbers from 1932 to 1970 are supported. Serial ...
Epiphone Serial Number Decoding - Gibson Brands Forums
forum.gibson.com > Gibson Brands > Epiphone > Epiphone Acoustics
Oct 30, 2017 - 5 posts - ‎4 authors
This serial number formats is solely used on Epiphone Elite or Elitist models. ... F-Serial Numbers onLes Paul Standard '59/'60 Models and ... Epiphone Les Paul Standard with TWO serial numbers?!?!
Dec. 11, 2011
Epiphone Les Paul Serial Number
Feb. 14, 2010
Look up your Epiphone Serial Number
Oct. 27, 2009
i.d. your Epiphone here -- serial # key, guitardater link + ...
Feb. 15, 2009
More results from forum.gibson.com
Gibson And Epiphone Guitars Serial Number Guide ' The Music Zoo
https://www.themusiczoo.com/blogs/.../gibson-and-epiphone-guitars-serial-number-gu...
May 4, 2011 - Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers.
Epiphone serial-number-information - identification ' Epiphone Guitars
www.epiphonetalk.com > Forums > The Guitar > Epiphone Guitars
Aug 11, 2017 - For Epiphone serial numbers that begin with a letter(s), this list ... F - Qingdao (China) = Les Paul Standard '59 / '60 / Tribute Models (See: ...
epiphone les paul standard serial number Google Search
Epiphone Music | Answered on Nov 26, 2018
That serial number was used more than once.
If it has 'Made in USA' on the headstock, it was made at the Bozeman Plant, MT, USA on July 21st, 2000.
Otherwise it was made in Korea in March, 2002.
Epiphone Music | Answered on Mar 31, 2018
That guitar was made in Korea in August, 2004
Epiphone Music | Answered on Jan 25, 2018
Epiphone Aj-100 Acoustic Guitar Logo
2 questions posted
Top Epiphone Music Experts
Robert Graf
Harrie
Marvin
Marvin
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
way turn truss rod guitar
  • Music
