20 Most Recent
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Questions & Answers
Ryobi 40 cc bar oiler not working
Hi and welcome to FixYa,
Areas/components to check/clean and ensure no clogging:
- oil filter
- oil line
- oiler pump
- worm gear drive
- bar
- oil hose/feeder to the bar.
For the exploded parts diagram of a PCN4040, pls click
here.
Good luck and thank you for using FixYa.
Ryobi Factory...
Answered
on Oct 25, 2018
Chainsaw chain sprocket won,t turn
this seems to be a chain brake that's applied , try turning off chain brake by pulling back on hand guard till a click is felt
some folks moving up from an older saw to a more modern saw are not so familiar with chain brakes and don't understand them and how they work
Ryobi Factory...
Answered
on Aug 31, 2015
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Ryobi Factory...
Answered
on May 20, 2015
Ryoby pcn 4040 tuning
I believe on low its 1 turn from closed and high is 1 and half turn from closed if not try the opposite way if you cant tell the difference clean carb and try again
Ryobi Factory...
Answered
on May 13, 2014
Ryobi 40cc chainsaw
Have you checked for spark? Sounds as though your ignition module has quit.
Remove the plug, connect a jumper wire between the threaded part of the plug and the cooling fins, Switch the ignition on, take it into a dark room and pull the starter. You should see a spark at the tip of the plug. HTH
Lou
Ryobi Factory...
Answered
on Jul 18, 2011
