20 Most Recent Cooper Industries Weller Field Soldering Iron, Controlled Output Questions & Answers
Contact the manufactu http://www.weller-toolsus.com/
Cooper... | Answered on Feb 22, 2019
The barrel to the soldering iron has a nut on it and the nut unscrews and the whole barrel comes off. The tip then comes out of the barrel.
Cooper... | Answered on Jan 17, 2013
Tip
Step by step procedures for soldering.
Most repair procedures on modern TVs require some kind of soldering. It is not a process which you can learn without spending some time getting the proper equipment and practicing until you can make a good solder joint in your sleep.<br /><br />First you need to understand that recently, within the last 5 years, the type of solder has been changed. Originally solder contained lead which can be dangerous, although I would wager that no one licks circuit boards! In order to make solder environmentally friendly more antimony has been added. This means that solder melts at a higher tempreture and does not adhere near as well. Flow is also compromised. Most solder joints now look like what we called cold solder joints in the past.<br /><br />To be able to solder correctly you will need a good iron or better yet a soldering station. You will also need to purchase some lead based solder and some solder with no lead. This is because you do not know at this point what circuit you will be working on.<br /><br />There are many vendors out there selling soldering equipment. <a href="http://www.mcminc.com/">http://www.mcminc.com</a> <a href="http://www.encompass.com/">http://www.encompass.com</a> <a href="http://www.digikey.com/">http://www.digikey.com</a> just to mention a few. <br /><br />The most versatile station would be a unit with an adjustable tempreture range. Then you can solder with lead based or non-lead solder. Lead based solder flows at about 750 degrees farenheith. The newer non-lead based solder flows at about 950 degrees farenheith. This means that you have to be extremely careful not to overheat components.<br /><br />If you cannot afford a variable tempreture unit you should probably purchase several pencil gun units. I would recommend getting a 25 watt, 35 watt and a 50 watt unit. Also get a good solder ****** and some solder wick. Do not get the cheap wick as it does not work after it corrodes due to the oxygen in the air. You will need the solder wick to remove any bad parts. <br /><br />When you are ready to solder let the iron or station heat up to the correct operating tempreture. Trying to solder too soon will give bad results. When the unit is hot and ready to go, place the tip (which should be conical) on the part to be soldered. Do not hurry it. Let it melt the solder and wait to see it flow before adding solder wick or removing the part.<br /><br />Reverse the procedure when soldering in a part. Do not have the iron in contact with the part any more than necessary as you may overheat the unti and damage it.<br /><br />If you follow these instructions you should be able to solder any board, part or device which needs it.<br /><br />Thanks for using FixYa and for the great rating.<br /><br />hardrocko<br />
on Apr 30, 2011 | Cooper Industries Weller Field...
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Cooper... | Answered on Jul 24, 2009
The #7 indecate a operating temp. of 700°F
It is problay the thermostat contacts that needs burnishing, that should fix it so that you don't have to buy a new heater / thermostat. Their parts are expensive.
Cooper... | Answered on Jul 08, 2009
Anti-Static Protection: If you're interested in soldering a lot of static-sensitive parts (e.g. CMOS chips or MOSFET transistors), more advanced and expensive soldering iron stations use static-dissipative materials in their construction to ensure that static does not build up on the iron itself. You may see these listed as "ESD safe" (electrostatic discharge proof). The cheapest irons won't necessarily be ESD-safe but never the less will still probably perform perfectly well in most hobby or educational applications if you take the usual anti-static precautions when handling the components. The tip would need to be well earthed (grounded) in these circumstances.
Cooper... | Answered on Aug 27, 2008
wires in lead to the handle may be broken
Welding Tools | Answered on Jul 11, 2020
the 8 setting nob is for what?
Welding Tools | Answered on May 31, 2020
It is possible to contact a vendor online:
https://www.wlenk.com/contact.php
Welding Tools | Answered on May 28, 2020
The correct current, or amperage, setting primarily depends on the diameter and type of electrode selected. For example, a 1/8-inch 6010 rod runs well from 75 to 125 amps, while a 5/32-inch 7018 rod welds at currents up to 220 amps. The side of the electrode box usually indicates operating ranges. Select an amperage based on the material thickness, welding position (about 15 percent less heat for overhead work compared to a flat weld) and observation of the finished weld. Most new welding machines have a permanent label that recommends amperage settings for a variety of electrodes and material thicknesses.
https://welderreview.com/yeswelder-15ft-250a-mig-welding/
Welding Tools | Answered on Apr 02, 2020
https://www.airgas.com/?s_kwcid=AL!10136!3!372572965137!b!!g!!%2Bwelding%20%2Bparts%20%2Bchicago&utm_arg=SEM:Google:SEM%20NB%20Local%20-%20Midwest:SEM%20NB%20Local%20-%20Midwest%20-%20Welding%20Parts%20-%20MBM:Search:372572965137:Local:Local::%2Bwelding%20%2Bparts%20%2Bchicago:b:Acquisition&gclid=EAIaIQobChMItKP_2q3C6AIVQtHeCh2qXwBGEAAYASAAEgLRkfD_BwE
Welding Tools | Answered on Mar 30, 2020
Cooper Industries Weller Field Soldering Iron, Controlled Output Logo
Popular Tags
12 questions posted
Top Cooper Welding Tools Experts
Bill Boyd
ray gallant
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Cooper Welding Tools
Most Popular Question
solder tip worn out need replace remove
  • Welding Tools
