20 Most Recent Homedics Deluxe Automatic Blood Pressure Monitor With Irregular Heartbeat Detector Bpa 150 1 Piece Questions & Answers
We have a Homedics blood
Trish, only the manufacturer, HoMedics can recalibrate it. As the calibration has to be certified as correct. Most manufacturers charge little or nothing to do this. Unfortunately, HoMedics is based in the USA in Minnesota. So, that means it was imported to NZ. However, they have a Customer Service email address [email protected] , that you can use to inquire about shipping it back to them for recalibration.
I hope this helps you and thanks for choosing FixYa.
12/18/2014 3:19:53 AM • Homedics Deluxe... • Answered on Dec 18, 2014
Is the instruction/owners manual for
No, unfortunately it's not. But you can obtain one by calling HoMedic's Customer Support at
1-800-466-3342. It can probably be emailed to you as an attachment.
Thanks for choosing FixYa.
8/10/2011 8:39:49 PM • Homedics Deluxe... • Answered on Aug 10, 2011
2answers
Lost manual
This link take you to Homedics web site...to the right of the picture you will see "Support Information" click that tab to download a useer manual....I hope this helps.
http://www.homedics.com/products/health-diagnostics/therap-deluxe-automatic-blood-presssure-monitor.html#more-info
12/24/2009 5:44:43 PM • Homedics Deluxe... • Answered on Dec 24, 2009
How can I retrieve the storaged memory from my
1st must install device drivers from a CD coming with your monitor. Then connect device to PC and if it has enough intelligence in its software it automatically will run a program on PC an retrieve data from device. Otherwise, after connecting device to PC, start the program on PC by clicking on its icon and follow instructions to save data on PC and display graphs etc...
9/8/2009 12:14:39 AM • Homedics Deluxe... • Answered on Sep 08, 2009
Blood pressure machine does not give heart rate infor
I finally got through to the company customer service person and found the machine has ''gone defective.'' They will pick up this one and send a replacement.
3/20/2009 12:24:19 PM • Homedics Deluxe... • Answered on Mar 20, 2009
This link should help...click on "Support Information" to the right of the photo...I hope this is helpful.
http://www.homedics.com/products/therap-automatic-wrist-blood-pressure-monitor-with-60-memories.html
1/7/2009 7:45:56 AM • Homedics Deluxe... • Answered on Jan 07, 2009
CA question
Check the battery. You may need to replace it. What does the manual say?
11/16/2008 2:44:54 PM • Homedics Deluxe... • Answered on Nov 16, 2008
I have replaced the batteries in my Homedics SC-531 body fat scale, but it will not turn on. Any suggestions?
If you have already tried replacing the batteries in your Homedics SC-531 body fat scale and are still unsuccessful, try the following: Voltage of the battery: Verify that the batteries are inserted correctly with respect to polarity. When you put the batteries in the compartment, make sure the marks on the inside match up with the positive and negative ends. Battery Reliability: Use new, high-quality batteries exclusively. It is possible for batteries to be low on charge or have a problem, even if they are brand new. Contacts for batteries: Be sure there is no debris or rust on the battery contacts located inside the battery compartment. Use rubbing alcohol and a cotton swab to clean the contacts if corrosion is visible. How to Reset: On the scale, you should see a button or other option to reset it. You can restart the system by pressing a little reset button that is located on some scales. For instructions on how to find and utilize this feature, consult the handbook that came with your particular model. Hold on a second. Do not attempt to power on the scale until one minute has passed after you have replaced the batteries. It may take a bit for some electronic gadgets to reset. Make sure nothing else is wrong. Check the scale for obvious signs of wear and tear, such as loose pieces or cracked surfaces. Get in touch with the manufacturer's customer service department if you run into any problems. Instruction Guide: See the instructions that come with the scale for further information. It might provide advice on how to fix common power problems or detailed directions for fixing specific problems. Get in touch with CS: Get in touch with Homedics's support staff if the troubleshooting instructions don't solve the issue. Depending on the problem you're experiencing, they might be able to provide you with more precise advice or suggestions. Always refer to the user manual for specific instructions on how to disassemble the scale before handling it, and be sure to follow any manufacturer-provided safety warnings. Contacting customer service is crucial if the scale is still within the warranty period.
11/25/2023 1:49:13 PM • Homedics Health... • Answered on Nov 25, 2023
HoMedics BPA-200 automatic blood pressure monitor. I cannot adjust years to 2023.
Question edited for clarity.You have probably had it too long. Ask the manufacturer if there is a software update they can do on it?Or is it because you have more than 2 years of saved data?Stay informed about your coronary health with this automatic blood pressure monitor that stores up to 60 readings with date and time stamp for up to 2 users.https://www.google.com/search?q=homedics+bpa-200+maximum..
8/17/2023 2:56:01 AM • Homedics Health... • Answered on Aug 17, 2023
3answers
I need to find the manual for a manicure/pedicure
its not necessary for u
4/10/2023 5:26:20 PM • Homedics Health... • Answered on Apr 10, 2023
2answers
My Homedics massager suddenly stopped working, is there anyway It can be repaired please ?
I have a homedics messenger. My turn on button is hard to find to trun on its very time consuming when you in pain. Can you help me with this issue. Sincerely Linnette Charles
1/4/2023 1:08:39 AM • Homedics Health... • Answered on Jan 04, 2023
Size battery for HoMedics digital Scale SC-300 V-1812
The HoMedics digital scale SC-300 uses a CR2032 lithium coin cell battery. This battery has a diameter of 20mm and a thickness of 3.2mm, which makes it a small, flat battery that can easily fit into the scale.
12/26/2022 5:04:01 PM • Homedics Health... • Answered on Dec 26, 2022
OSIM uCrown 2 Soothing Head Massager. Why won't my uCrown2 turn on?
Question edited for clarity. Question moved from Computers and Internet category. Batteries not fresh, or incorrectly inserted. This appears to be a device without a maker. Chinese 'sell and run'. https://www.google.com/search?q=uCrown2&rlz=1C1QJDB_enCA643CA644&sourceid=chrome&ie=UTF-8 ..
3/7/2022 9:36:12 PM • Homedics Health... • Answered on Mar 07, 2022
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager? If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience. Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off. Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart. Good luck.
2/6/2022 5:21:23 PM • Homedics Health... • Answered on Feb 06, 2022
Homedics total clean does't work on fan
Plug the power cord into a standard AC outlet. Turn the air purifier on. Press and hold the ionizer ION button for 3 seconds to reset the indicator.
11/20/2021 8:18:53 AM • Homedics Health... • Answered on Nov 20, 2021
Homedics Deluxe Automatic Blood Pressure Monitor With Irregular Heartbeat Detector Bpa 150 1 Piece Logo
14 questions posted
Top Homedics Health & Beauty Experts
jws1013
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Homedics Health & Beauty
Most Popular Question
homedics blood
  • Health & Beauty
