20 Most Recent Pride Revo 4 Wheel Travel Scooter Questions & Answers
Golden's website has a service manual to download. The wiring diagram is in it along with complete instructions on how to maintain and repair your scooter.
Pride Revo 4... | Answered on Feb 24, 2015
Hi. A faulty speed control pot ( wig wag ) will cause this problem.
While you are driving along on a smooth surface, move the end of the lever carefully up and down, not in and out as you normally do. Doing this will help to see if there is a problem with the pot, it will cause the speed to vary or change.
Can sometimes be caused by stuck or worn motor brushes.
Good luck. Neil.
Pride Revo 4... | Answered on Jun 18, 2010
1. Defective battery
2. Defective charger
Pride Health &... | Answered on Oct 29, 2020
This is how we managed to take of our seat.Ir takes 2 strong people to turn the seat whilst pressing the lever under the seat ,you will feel a quiet click,near the seat post this is the area that will allow the seat to be lifted of,might you no where I can find the vin chasis frame number and engine number,i have asked this question in a post sent today.
https://www.youtube.com/watch?v=J2gB3FGUJXc
A lot of times when the mobility scooter cuts off, the gauge on the battery drops to zero. ... The most common reason for a fast-depleting battery is age. As batteries age, they store less charge and are less efficient. So not only do they lose their charge faster, they have little of it to begin with.
https://activeseniorsclub.co.uk/mobility-scooter-keeps-cutting-out/
Pride Health &... | Answered on Apr 17, 2020
8 flashes means there is a power module issue. Check the connections at the battery and power module. If ok, check the battery, it may need replacing.
Pride Health &... | Answered on Jan 28, 2020
ow To Fix Your Scooter That Won't Turn On Or Charge - YouTube
https://www.youtube.com/watch?v=rgK2l6cMCc4
17 Mar 2017 ... GoGo Or Go Go power chair repair. How to replace the batteries in the sealed battery box on your power chair scooter. Battery: UB12180.
Pride Health &... | Answered on Jan 24, 2020
One light flashing means: The batteries need charging or there is a bad connection to the batteries. Check the connections to the batteries. If the connections are good, try charging the batteries.
Pride Health &... | Answered on Dec 24, 2019
hi Peter at worse, ,sounds like a controller fault, are you uk based?
could be that the motor brushes are causing the fault.
If so i can repair them from £20.
regards
Rob
Pride Health &... | Answered on Dec 22, 2019
The flashing light is flashing a code that indicates an electrical problem. See your manual for the codes on pg 38.
Pride Health &... | Answered on Dec 14, 2019
Pride Revo 4 Wheel Travel Scooter  Logo
5 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Mike
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
wiring diagram golden companion
  • Health & Beauty
