20 Most Recent Pride Legend XL Heavy-Duty 4 Wheel Scooter Questions & Answers
Oh yes it will! They can be very stiff and heavy, get help and mind your back! Release the seat swivel leaver and wiggle the seat left and right as you rupture yourself lifting..... You probably need help I do these days.
Pride Legend XL... | Answered on Aug 02, 2016
From Pride, MK batteries or your local mobility service centre.
Have you checked eBay for mobility scooter chargers. be careful on second hand chargers.
Pride Legend XL... | Answered on Jun 17, 2015
Your thottle lever and speed pot need resetting
Pride Legend XL... | Answered on Jul 29, 2014
If it is actually speed pot related, then removing the speed pot
and spraying down the shaft of the speed pot (from the top)
with electronic contact cleaner, may help to make clean
the pot resistive element and that should fix that. If it's
not a speed pot issue and happened after replacement of
the batteries, assuming they are 35/37 AH AGM batteries,
check the batteries for current delivery at the rated current.
It could be just a battery that is not providing the rated current
to the motor after 50 feet.
Pride Legend XL... | Answered on May 02, 2014
The problem of your legend XL can view from two different ways and also be view at same time from point.
1). From the wire connections and
2). From the ulterlator (i.e motor battery changer).
What you are to do to fix up this problem is to carefuly trace the wire of the power connector if it providing power on to the battery ,if dose not then it means that there is a power faile from the power which has been the couse of the power faile of the battery.
Then the wireing programm will need to be rerun so a to solve the battery problem.
Thank you and thank for using fixya.
Pride Legend XL... | Answered on Oct 02, 2010
Don about the only thing left to check is the brushes in the motor and the brake. You can remove the brush caps and check to make sure that the brushes are not worn badly. You can also chek the rear of the scooter where the brake and the motor are attached and after a period of driving this area can be warm but not very warm or hot to touch. If it is hot or very warm then the brake is dragging and causing an excessive draw on the batteries. You can have the brake replace or take it off and clean the brake pad. Careful don't pull or break the wires going to the brake. Hope this helps let me know if it did Good Luck
Pride Legend XL... | Answered on Oct 01, 2010
hi i hsave a pride legend classic mobility scooter it will run ok for a few yards then suddenly stop but if u wait for a bit it will go again whats the problem thanks
Pride Legend XL... | Answered on Aug 03, 2010
The one thing that wouldn't cause the noise is the batteries.
If it is an electrical noise, it will be the speed controller as they go slower in reverse than in forward.
If it is mechanical, it might be the brake or the motor drive. Take it to your local dealer for correct diagnosis and repair IF needed.
Pride Health &... | Answered on May 20, 2020
https://www.youtube.com/watch?v=J2gB3FGUJXc
A lot of times when the mobility scooter cuts off, the gauge on the battery drops to zero. ... The most common reason for a fast-depleting battery is age. As batteries age, they store less charge and are less efficient. So not only do they lose their charge faster, they have little of it to begin with.
https://activeseniorsclub.co.uk/mobility-scooter-keeps-cutting-out/
Pride Health &... | Answered on Apr 17, 2020
8 flashes means there is a power module issue. Check the connections at the battery and power module. If ok, check the battery, it may need replacing.
Pride Health &... | Answered on Jan 28, 2020
ow To Fix Your Scooter That Won't Turn On Or Charge - YouTube
https://www.youtube.com/watch?v=rgK2l6cMCc4
17 Mar 2017 ... GoGo Or Go Go power chair repair. How to replace the batteries in the sealed battery box on your power chair scooter. Battery: UB12180.
Pride Health &... | Answered on Jan 24, 2020
One light flashing means: The batteries need charging or there is a bad connection to the batteries. Check the connections to the batteries. If the connections are good, try charging the batteries.
Pride Health &... | Answered on Dec 24, 2019
hi Peter at worse, ,sounds like a controller fault, are you uk based?
could be that the motor brushes are causing the fault.
If so i can repair them from £20.
regards
Rob
Pride Health &... | Answered on Dec 22, 2019
The flashing light is flashing a code that indicates an electrical problem. See your manual for the codes on pg 38.
Pride Health &... | Answered on Dec 14, 2019
Pride Legend XL Heavy-Duty 4 Wheel Scooter  Logo
Popular Tags
13 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
scooter electronic brake doesn t seem
  • Health & Beauty
