20 Most Recent
Pride Celebrity X 3-Wheel Electric Scooter Questions & Answers
Flashing light error
Download the service manual from Pride's website for detailed instructions on what the flashes mean and how to fix it.
Speed pot error
The speed pot needs to be checked for a loose connection. If it looks good then the pot needs replaced.
Shroud function
It's the red battery cover under the seat. Carefully lift and remove the seat and you'll find that the shroud is simply attached with velcro
Celebrity x charging fuses
Hidden under the floor mat and hatch, you'll find two high amp fuses that Pride say don't exist! - they do. Be careful with the rubber mat lugs they deform and are tricky to reseat.
the fuses are standard car fuses. It's busually the red 10 Amp fuse that's blown.
the cause of the problem may possibly be the three pin XLR cable/ plug.
Why wont my celebrity x3 charge
Try the Charging circuit fuses hidden under the mat and floor hatch.
Is the charger OK?
Are the batteries coming to the end of their life?
Battery won't charge
If the battery wont charge the item will need a service engineer to test it. I am not sure of the particular model but there is a possibility that either the charger itself is at fault OR the charging circuit has either a diode or capacitor damaged.
If the charger plugs into a 240v socket in the house have the charger checked to show voltage is being output by it.
If it is then how old is the battery on the scooter? does it need replacing? have a voltage test done.
If both the battery and wall charger if there is one is OK then I would say another part of the vehicles circuitry made be at fault and suggest you have it looked at. .
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,1. Any clicking from the rear .Please keep me updated.Regards
Motor voltage error Code 8
Possible Control System Trip
A control system trip is indicated. Make sure that all connections are secure.
Why won't it operate?
How many flashes on green light. Count them and you should find in the trouble shooting section of your user manual what the problem is. Most cases you can sort yourself.
More on Celebrity X motor overheating. Brushes look good. Brake does not seem to be dragging, Batteries are about 5 years old but hold a good charge when not in use for months,
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Turns on won't move
Flashing error codes
Carefully count the number of flashes that occur in each sequence; for instance, it will flash 5 times, pause, and flash 5 times again. Go through several sequences to make sure your count is correct as it will always be the same number of flashes.
Here is the owners manual, go to page 37 to find the flash code page and look up your number. Then post that back here for more information on how to proceed.
What makes the speed pot go bad on a 3 wheel celebrity x scooter
Yup you gt a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pt is aa variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this You may also need a VOM meter only $9 http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should movee gracefully up to 30k down to zero as the pot dial scooter speed increases. Faaailure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
When I take my scooter
I have to ask who and how were the battery's checked. Lead acid battery's can show good if checking for voltage but lack the amps needed for continual use. Check the charger for voltage output, gain access to the battery's hook up your charger. Read the voltage on the battery with a voltage meter before and then after you hook up the charger. You should have a 2 to 3.5 volt increase after the charger is turned on. Once the charger tells you the battery's are fully charged re-read the voltage with the Charger still on then remove the charger or turn it off. The battery's voltage should stay at least 1.5 volts above the battery rated voltage. Now, if your battery's are the original that came with the scooter and they are 2 - 3 years old, it may be time for a new set. Yes you could have some voltage drain, the best way to check for that is, disconnect the negative battery cable, using a voltage meter read voltage in-between the cable end and the battery post or touch it back to the battery post lightly if you see a spark you have a voltage drain. Battery's are a bit tricky, they can produce good voltage but if the plates loose there ability to produce amps it is hard to find without a "amp load test", That is a test of the battery's amp hour rating or " cold cranking amps" (CCA) even the battery's in your scooter should have this rating. Hope this helps.
