20 Most Recent Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Questions & Answers
hi , sounds like the brake is clicking which in this case is normal, sometimes as the brake wears the clicking get nosier. Can you please confirm where the clicking is coming from ??.
Regards
Rob
www.gewizrepairs.co.uk
Pride Mobility... | Answered on Mar 05, 2014
that could be that you need a new pot for spped control bar, is there any up and down movement ? if yes that could be intermittant
Regards
GeWiz.
Pride Mobility... | Answered on Jul 30, 2013
hi, okay now does this happening every time ? or is the distance variable ?
check the batteries are fully charged, if possible check the batteries with a electrical meter when it stops again , insert the probes in the charger socket the outside ones , the middle on you can ignore , check the voltage , below 23 or 24 volts this means that once you start going again the voltage will drop causing the controller to cut out , they normally cut out at about 18 volts .
Satisfied that's okay now the brake could be breaking down ? do you hear it click when going along ?
At worse your controller could be breaking down
Regards
Pride Mobility... | Answered on Jan 20, 2013
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Pride Mobility... | Answered on May 07, 2009
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
Pride Mobility... | Answered on Apr 03, 2009
Sounds like you have a bad charger. If you have access to a volt meter you can set it to volts DC put the meter to the batteries then plug in the charger. If the volts go up on the meter after you plug in the charger is working ok.
Pride Mobility... | Answered on Apr 01, 2009
use some sissors like sharp thing to insert inside and try then
Pride Mobility... | Answered on Jan 29, 2009
From a pure physics standpoint...
The energy to climb a hill... be it from the steep side or the gentle sloping side is the same...
It is just easier on your heart and joints to take the gentle slope... (assuming you have the time).
ERGO:
If treating the scooter like a QUEEN
is your goal... DEFINITELY GO SLOW.
Tat way you will have no idea if it has any weak spots when you need it to go fast (and you will).
I'm old... I don't have TIME to waste!
Carnac the Magnificent
Pride Mobility... | Answered on Mar 28, 2017
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Pride Mobility... | Answered on Sep 03, 2016
Maybe too late for this advice but it is important to take a detailed photograph of the wireing before unplugging anything.
Pride Mobility... | Answered on Jul 02, 2016
I'd recommend a dental pick.
Pride Mobility... | Answered on Jun 01, 2016
Hi not much info is there a red LED & green LED on charger...or is there a red LED & orange led on ?? Bit more info would help cheers
Pride Mobility... | Answered on May 16, 2016
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Logo
13 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
scooter started make clicking noise
  • Health & Beauty
