20 Most Recent Pride Mobility Products Pride Victory 10 - Three Wheel Questions & Answers
hi Taffie, that related to the freewheel lever or brake
make sure the at the lever is not bent and make sure connection to the brake are okay , there is a micro-switch located on the brake make sure that's releasing when you move the lever... it like a rounded plastic point , that is part of the switch and sometimes they stick so acting like it 's in freewheel when in fact it isn't ...
Regards
Rob
Pride Mobility... | Answered on Feb 20, 2016
hi ring pride 1-800-800-8586 about youre problem It could b a fault with youre control box ......good luck
Pride Mobility... | Answered on Nov 30, 2015
hi , normally this can be a bearing running dry or a worn bearing ballrace ..... is it possible to get one off the floor so it will spin... please take great care when carrying this out... running the scooter like this will allow to pinpoint where the noise is coming from...
Regards
Rob
www.gewizrepairs.co.uk
Pride Mobility... | Answered on Feb 05, 2015
Hi , if the scooter goes into reverse okay , it could a be throttle issue , or the forward logic( mosfet out put ) of the PG Drives controller has failed...
I offer free testing if based you're in the UK...
Regards
Pride Mobility... | Answered on Jan 26, 2015
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Pride Mobility... | Answered on Nov 25, 2014
8 beeps means possible Controller fault.
Pride Mobility... | Answered on Nov 06, 2014
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest....
Regards
Pride Mobility... | Answered on Nov 16, 2013
check battery's separate 1 may be dead
Pride Mobility... | Answered on Mar 27, 2013
This sounds to me like you need a cleaning of all electrical connections that you can get to. I would remove cable from negitive side of the battery first and leave it disconnected until you are finished. Clean both battery cables using a wire brush sand paper or whatever you can to clean. I would also have the battery tested. Some auto parts stores such as auto zone will do this for you for free.
You probably will need to have most of this work done by a service tech, as it sounds like the throttle control is going to need work and the only units like yours that I have worked on were not user friendly.Sorry I'm not more help. Thank you
Pride Mobility... | Answered on Jan 07, 2011
yes this is a common problem on a victory scooter i know i have one and the same problem just solder it up carefully
Pride Mobility... | Answered on Jul 11, 2010
If the click is coming from one side of the rear of the scooter, I would think you have a dry axle. If this is the case, you will hear a regular clicking noise, just as if there is a stone in the tyre. All you have to do is remove the wheel, apply some grease to the axle and re-fit the wheel again. When removing the wheel, be careful not to loose the hub key (usually a small strip of square metal that fits in a groove in the axle and wheel). This clicking noise is a very common problem with Pride scooters and one we regularly deal with, even on brand new scooters. If this doesnt cure your problem there are a number of other things it could be, but i would need more specific details to try and help you. Hopefully its just the axle! Hope I have been of some help to you.
Pride Mobility... | Answered on Mar 23, 2010
MANY HAVE A BAR THAT WHEN THEY NEED PUSHED BY HAND IT DISENGAGES THE DRIVE .
Pride Mobility... | Answered on Mar 06, 2019
WELL POSSIBLY IF WE KNEW FOR WHAT BUT ALAS WE DO NOT
SORRY BUT WE (FIXYA) DO NOT SEARCH FOR PARTS .FOR ANY ONE . CALL YOUR LOCAL REPAIR SERVICE .
Pride Mobility... | Answered on Feb 15, 2019
From a pure physics standpoint...
The energy to climb a hill... be it from the steep side or the gentle sloping side is the same...
It is just easier on your heart and joints to take the gentle slope... (assuming you have the time).
ERGO:
If treating the scooter like a QUEEN
is your goal... DEFINITELY GO SLOW.
Tat way you will have no idea if it has any weak spots when you need it to go fast (and you will).
I'm old... I don't have TIME to waste!
Carnac the Magnificent
Pride Mobility... | Answered on Mar 28, 2017
Pride Mobility Products Pride Victory 10 - Three Wheel Logo
Popular Tags
13 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
4 wheel pride victory 10 scooter
  • Health & Beauty
