20 Most Recent Northstar Generator 9 Hp, 5500 Watt, Gasoline Questions & Answers
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Northstar... | Answered on Jan 06, 2020
check AVR card...most of the times it is the prob.
if it works...then chek brushes..
then wireing...
i hope i helped...send me an email for more details
Northstar... | Answered on Oct 25, 2015
Hi, you can find them on amazon. Take a look here: Portable Generators from Briggs Stratton. I hope this was helpful. Cheers
Northstar... | Answered on Dec 10, 2014
Check the connections between the alternator (generator) and the regulator/output connectors.
Northstar... | Answered on Nov 07, 2014
It's very common for the connectors between the alternator and power outlets to come loose on these. Give them a check and tighten as necessary.
sounds like the carb should be pulled off and cleaned.Make sure to clean the jets and needle valve
Northstar... | Answered on Oct 28, 2012
I am just closing this out. Asker has manual.
Kelly
Northstar... | Answered on Aug 12, 2012
there are two things in generator out put
one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
53 questions posted
Top Northstar Electrical Supplies Experts
Sheldon Dedek
john h
Marvin
Marvin
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Northstar Electrical Supplies
Most Popular Question
north star generator parts
  • Electrical Supplies
