20 Most Recent
Plantronics CT 12 Cordless Phone (CT12) Questions & Answers
Plantronics CT-12, the red light
You need to disconnect for a few seconds and reconnect the battery on the remote. While the remote is sitting in the charging cradle, press the talk button to turn on the remote and then turn off. Disconnect the ac power from the base for five seconds and reconnect. This should subscribe the two pieces together.
Good luck from
Headsets Direct!
Callers can't hear me when I answer the phone
Went to Plantronics website and did the chat support. Was told to take the battery out and leave it out for 10 seconds so the phone would reset. It then worked for about 10 minutes and did it again midcall. So it kinda works, but not a reliable fix.
How to make a pause
Common "PAUSE" buttons are P, a comma "," , or the old fashioned method of waiting for a few seconds.
You might have an ALT key or SHIFT key. Try that.
Forgot how to par my
To pair with a Bluetooth device:
- Make sure the device's Bluetooth radio is on.
- Set the handset's Bluetooth discover mode to On.
- Select the appropriate Bluetooth accessory.
- Enter your PIN number.
Once a Bluetooth accessory has been paired with the device, it can be
used with the device, without the need for re-pairing, assuming the
appropriate profile exists for the required service.
Hello there! When I try
maybe it is recognizing it as another phone device, instead of a headset. you can also try leaving the second request for a code blank
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit
http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM •
Lands Phones
Answered
on Mar 21, 2024
