20 Most Recent Gold Medal 2005 Deluxe Whiz Bang Popcorn Maker Questions & Answers
Would like to check the Gold Medal thermostats in my model #2003 machine. The 550f for 12, 14, 16oz kettles p/n 47082. Do they check good with a resistance value? And do you know what they should m
You can test it for continuity. Remove from the circuit, set your meter to highest Rx value. Using heat gun, hair dryer on high or candle heat the t/stat. At some point it will click on/off depending on type. If its a NO it will click on, then off on removal of heat, if its a NC it will click off then on, with removal of heat. Many times the trip temp is printed on the body.
11/5/2014 7:26:05 AM • Gold Medal 2005... • Answered on Nov 05, 2014
Gold Medal 2005 Popcorn Maker electricutes you if no shoes on
That machine is not properly grounded. If it was it would be tripping the breaker every time.Somewhere there is a ground fault in the machine, any wire or heater is suspect, also the broken light bulb is suspect.Get the machine grounded properly, and start flipping switches. which every switch trips the breaker, that is where to start looking for the ground fault.
2/18/2013 7:04:39 PM • Gold Medal 2005... • Answered on Feb 18, 2013
We are looking for the
Available replacement parts for the Gold Medal line can be ordered from this site
http://www.gmpopcorn.com/store/index.cfm
I did not see the part you are looking for and before looking on the second hand market would recommned you contact Gold Medal Technical Support at 1-800-543-0862.
4/25/2011 7:38:46 PM • Gold Medal 2005... • Answered on Apr 25, 2011
The popcorn is not popping.
You may not be using enough oil. You should have 3 measures of popcorn, to one measure of oil. So if you are using 12 ounces of corn, you should use 4 ounces of oil.
3/15/2011 4:03:26 PM • Gold Medal 2005... • Answered on Mar 15, 2011
Gold Medal Products Whiz Bang
Have you checked to assure that the warmer switch and the kettle heat switch are both functioning properly? Also the timer on the bucket seasoning pump control box determines the length of time the heat element of the bucket pump is at HIGH HEAT i also suggest you take a look at this pdf of the manual of your machine under the troubleshooting guide area if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
http://lib.store.yahoo.net/lib/yhst-81132447584496/47699.pdf
12/21/2010 6:39:28 AM • Gold Medal 2005... • Answered on Dec 21, 2010
Gold medal Tornado cotton candy machine stopped working
Unlikely to be the plug adapter. That would just trip the breaker. Your issue is likely to be leaking voltage from the motor windings. I had this with a 1950s desk fan.
8/18/2022 5:22:16 PM • Gold Medal... • Answered on Aug 18, 2022
Where can i buy a heat lamp bulb for my popcorn machine
Go to http://www.PopcornBulbs.com
10/29/2020 6:29:28 PM • Gold Medal... • Answered on Oct 29, 2020
What was the use date on the Gold Medal flour?
You are probably concerned about the recent Salmonella issue? The product is the UNBLEACHED all purpose flour: Gold Medal Unbleached All Purpose 5LB Flour Package UPC: 000-16000-19610-0 Recalled Better if Used by Date: 20APR2020KC The "use by date" is ink dot printed on each package, usually toward the bottom of the package somewhere.
1/24/2019 7:23:42 PM • Gold Medal... • Answered on Jan 24, 2019
I need INSTRUCTION MANUAL for Rodger Black Gold Medal treadmill JX 286
Look on the Argos GB wesite.
12/30/2017 1:39:21 PM • Gold Medal... • Answered on Dec 30, 2017
I purchased a 1023 Maximizer from you guys years
wrong site fixya doesnt sell products
12/22/2017 3:02:04 PM • Gold Medal... • Answered on Dec 22, 2017
How Much longer can Gold Medal Self Rising flour be used with an expiration date of 10 July 2017
It all depends on the conditions of its storage and the climate where you are baking. As long as it still rises, it's good to go. The dates tend to be very conservative.
12/19/2017 6:14:34 PM • Gold Medal... • Answered on Dec 19, 2017
0answers
Gold Medal 2005 Deluxe Whiz Bang Popcorn Maker Logo
11 questions posted
Top Gold Medal Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Gold Medal Kitchen Appliances - Others
Most Popular Question
like check gold medal thermostats in
  • Kitchen Appliances - Others
